It is currently Mon Jul 07, 2025 9:11 am
PostPosted: Mon Jun 08, 2020 10:50 am
Hello,
I have a rod change gearbox and am looking to replace the oil seals on the rods.
I struggling to source replacement oil seals. Any recommendations please.
PostPosted: Mon Jun 08, 2020 10:54 am
If its the box in the picture then its a remote box. No seals where the selector goes through the box. Only bushes. Hope this helps
Sent from my SM-J530Y using Tapatalk
PostPosted: Mon Jun 08, 2020 2:41 pm
The blue gearbox in your photo is a remote type box.
In the centre of photo where the shaft goes through the gearbox casing at an angle, there appears to be a bush. Normally there is only a seal - p/n 13H577 and not a bush at this point. This may have been added by another owner.
There are 2 bronze bushes in the diff cover. One can be seen at top,right where the selector shaft comes out of the diff housing and is bolted to the female selector toggle.
The other bush is at the lower end of the same shaft.
Users browsing this forum: Bing [Bot], wild_willy and 115 guests
