1275cc |
Joined: Sat Feb 09, 2013 5:44 pm Posts: 2236 Location: Camden
The blue gearbox in your photo is a remote type box. In the centre of photo where the shaft goes through the gearbox casing at an angle, there appears to be a bush. Normally there is only a seal - p/n 13H577 and not a bush at this point. This may have been added by another owner. There are 2 bronze bushes in the diff cover. One can be seen at top,right where the selector shaft comes out of the diff housing and is bolted to the female selector toggle. The other bush is at the lower end of the same shaft.
