It is currently Thu Jul 17, 2025 9:44 pm
PostPosted: Thu May 14, 2020 7:16 pm
I have sorted quite a few issues with the motor and finally have a reasonable idle and passable acceleration. Im taking it easy until it beds in more but when I take a corner at any speed it seems to die off. It isn't a "miss" as such, i just have to take my foot off a bit then it recovers. Any ideas?
Is it surging or emptying Fuel somewhere?
Sent from my Nokia 5.1 Plus using Tapatalk
PostPosted: Thu May 14, 2020 10:29 pm
I would probably start by checking your float level/s.
PostPosted: Fri May 15, 2020 11:13 am
or float bowl lid orientation
PostPosted: Fri May 15, 2020 11:44 am
Yeah had issues with the lid when I tried using one off a 1 1/4. It has a non bendable float in it and the gap is a little big. I'll have a go on the weekend.
PostPosted: Fri May 15, 2020 6:33 pm
Oh dear, worry, worry...
Hi Bluehishouse
One issue minis suffer from when driven with a bit of spirited driving round corners mostly right hand corners the float shuts off the fuel.
To over come this you have to turn the float lid around so that when you are under brakes the float will go forward shutting off the fuel.
This means it will be open under acceleration and round corners, BUT the inlet pipe will be facing the body of the carbie bit hard to get the fuel pipe on some times.
Graham Russell
PostPosted: Fri May 15, 2020 7:05 pm
Ah i see. I have miles of hose. Is there any issue putting an angle barb in a fuel line? Other than extra points to leak.
PostPosted: Fri May 15, 2020 10:31 pm
GR wrote:
Hi Bluehishouse
Graham Russell
Yes Graham, Also effects 246 Dinos
PostPosted: Sat May 16, 2020 7:54 am
Hi bluehishouse
NO that would be fine let me know how it goes.
Graham Russell
PostPosted: Mon May 18, 2020 9:06 am
In theory an HIF carb with a concentric float bowl should be better than an HS, but I don't run one.
My 45 Dellorto doesn't do it.
PostPosted: Mon May 18, 2020 10:37 am
I haven't driven yet but the lid would surge one way as it was sitting. I turned it one screw to face as GR said. Makes sense. Blue slip done rego this week then ill give it a real belt!
PostPosted: Mon May 18, 2020 10:41 am
I reckon it will be the float bowl orientation
PostPosted: Thu May 21, 2020 8:19 pm
My HIF doesn't suffer from that, but I also have a float bowl spacer to give more volume. Forgive my ignorance, I am not sure whether there would be a way to enlarge the float volume in the HS, given its engineering.
Sent from my Pixel 3 XL using Tapatalk
PostPosted: Thu May 21, 2020 9:03 pm
One way that has been used over the years on racing cars is to run two float bowls. (not usually seen on Minis though)
PostPosted: Thu May 21, 2020 10:23 pm
Would hardly need 2 on a mini. The issue i struggled with is its relative height to the jet it comes out of. Does having it low affect the flow? Or does it just make it run dry
PostPosted: Fri May 22, 2020 12:03 pm
I have seen float bowl extensions on race cars.
https://www.med-engineering.co.uk/h4-su ... extensions
https://swiftune.com/parts-shop/carbura ... ats-2.html
