It is currently Fri Jul 04, 2025 7:02 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Engine Vibration
PostPosted: Sun Apr 26, 2020 9:22 am
If you take a stock flywheel to Graham his big lathe is set up for flywheel lightening, he could do it while you wait.
PostPosted: Sun Apr 26, 2020 9:59 am
Would there possibly also be Tim-Tams and Tea or Coffee available as well Doc :?: :lol:
PostPosted: Sun Apr 26, 2020 10:28 am
Already offered see GR's post above. :P
PostPosted: Sun Apr 26, 2020 12:12 pm
Don't have a stock fw and gr is 6hrs drive from me. In the Maloo that is probably $150 in fuel! Still paying $1.35 ltr up here on the north coast
TOZOOM has offered me one for $180.
Just got to get hold of him again to finalise the transaction
Sent from my SM-G950F using Tapatalk
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 2:03 pm
Hah! but that was for those horribly crumbly Monte Carlo's (appropriate for a Mini tho)...
PostPosted: Sun Apr 26, 2020 3:24 pm
Chocolate Montes trump both. :P keep in fridge.
/end thread
PostPosted: Sun Apr 26, 2020 5:41 pm
Clutch fibre plate is strange. Doesn't have any grooves. Says fraymon. Looks like lighter type pressure plate so that is good. Stripped 3/8 thread photo also attachedImageImage
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 6:58 pm
That looks like a Quinton Hazell backplate. I had one, it was miles out of balance when checked.
I would get it balanced with the flywheel if you are going to use it.
PostPosted: Sun Apr 26, 2020 7:20 pm
Will have to see how it goes first I think. Budget will be blown with new flywheel. If the fw transaction doesnt eventuate, another option would be to send it all to GR and get it all balanced and the stripped thread fixed at the same time
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 7:33 pm
/end thread
Now ya talkin! :D
PostPosted: Sun Apr 26, 2020 7:56 pm
Oh dear, worry, worry...
Hi mini66
The best thing you can do is get rid of that flywheel the reason being they have turned the centre boss down BAD MOVE :cry:
The boss has no strength when this is done, and with use it will move up the crankshaft and you will not get it off and possibly taking out the crank and flywheel, been there don that.
I tried to alert MED about this problem with his flywheels after a lot of cranks were ruined in Aust but he did not listen said there was not a problem.
Funny 12 months later his flywheels came out with a much larger boss, now he cuts little slots all around the boss and no heat sink and you wind up with 3 big hot spots around the flywheel :shock:
Graham Russell
PostPosted: Sun Apr 26, 2020 8:05 pm
Hi Graham, thanks mate, great help. It was already bloody hard to get off. Needed a long bar on the puller. I will get a new fw and use the pressure plate I have and see how it turns out. Pressure plate still has the machining marks on it. (although could be a dodgy brand typically out of balance).
Have you seen a fibre plate without grooves like that before?
Rick
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 8:18 pm
HI Rick
Yes, I cut groves in the backing plate and flywheel.
Graham Russell
PostPosted: Sun Apr 26, 2020 8:25 pm
Ok makes sense.
It still has the writing on the face so I will reuse it and see how it goes.
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 8:30 pm
In your opinion is 37 grams a lot to be out of balance for the flywheel?. This is what the missing bolt and spacer weighed
Thanks again
Rick
Ford DF LTD - 5Ltr
Users browsing this forum: John Sneddon and 82 guests
