It is currently Wed Jul 09, 2025 8:46 pm
PostPosted: Mon Sep 16, 2019 6:38 pm
Hi everyone,
I need help.
I have pulled the engine bay wiring apart because the previous owner was a HACK and the wiring was dangerous.
I have everything else worked out except for 2 brown wires and 1 brown/red wire that are from the engine bay wiring loom.
The car had a newer engine installed in it by the previous owner - which is a 1275cc from 1990 onwards.
Any MPI/SPI is gone and it runs a carby now - also done by the previous owner.
What I know about the wiring is:
One of the Brown wires and the Brown/Red wire go to a Relay - that is located on the firewall close to the drivers side.
The ends of these wires are at the front of the car - no connectors - they are cut.
The other Brown wire (I believe) connects the starter solenoid to the Ignition.
I have looked at many diagrams and manuals and I can't see anything similar. I have also looked at SPI to Carb pages for ideas.
Jason.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Mon Sep 16, 2019 7:13 pm
This is an image that I have found which looks close to what I want BUT it isn't in line with the relay wiring.
Currently the Brown and Brown/Red wires are connected to the relay.
The diagram shows that:
- the brown wire connects from the Starter to the Fuse box.
- the Brown/Red wire connects from the Starter to the Relay
- a Brown wire connects from the Relay to the Fuse box
I could do this by removing the current Brown wire from the Relay and connect it to the Fuse box.
But then... what fuse/link would I use?
Jason
PostPosted: Thu Sep 19, 2019 5:17 pm
1 Brown wire goes from the Starter solenoid to Starter Relay
The other Brown wire goes from the Starter solenoid to Ignition
The Brown/Red wire goes from the Starter solenoid to Starter Relay
Done.
