It is currently Sun Jun 29, 2025 11:10 am
 Post subject: 998
PostPosted: Wed Jun 08, 2005 7:33 pm
Gday all
whats the best way to fully do up a 998??
appart from getting rid of it :lol:
thanks guys
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Wed Jun 08, 2005 7:35 pm
atm mine is 60thou over (1060cc) with a 997 cooper cam.
thats it. gave it a rough tune today but it goes well for what it
is. stanfard 1.5 carby and sstandard exhaust. with extractors and
twins and a ported and polished 12G202 head she will go even better :wink:
PostPosted: Wed Jun 08, 2005 7:36 pm
Head work, extractors, carby, bore it out, stroke it etc
PostPosted: Wed Jun 08, 2005 7:58 pm
Mine ....
998, low compression, Pulsar Dizzy, HIF-6, Oh, and a Turbo.
J
PostPosted: Wed Jun 08, 2005 7:59 pm
I guess at Turbo is out of the question now if you're a P plater.
There goes the golden days for the young sensible driver....
PostPosted: Wed Jun 08, 2005 8:02 pm
If you are CURRENTLY a P plater you canb still drive Turbo/Supercharged/V8
only NEW P platers are affected :)
After seeing James' Turbo 998...im very impressed with what you can get out of a 998.
PostPosted: Wed Jun 08, 2005 9:40 pm
Max, hold your impressions......
In a few weeks we should be back and nastier than ever ......
I think i've found room for the intercooler AND the water injection......
And with a DRMINI special head on........ yay.. lets play.
J
PostPosted: Wed Jun 08, 2005 9:47 pm
James proves yet again that a 998 isnt to be laughed at!!
I shudder to think what it would be like as a passenger when its done ;).........I CALL SHOTGUN WHEN ITS BACK :D
PostPosted: Wed Jun 08, 2005 10:19 pm
JAM =
998 block
+.020" pistons
Balanced 1098 crank
RE13 MkII cam
202 ported head with oversize valves
Twin SU's
Should go aiight!! :wink:
PostPosted: Wed Jun 08, 2005 11:06 pm
Spare S cam for my 1430 stroker is going in to GR's for grinding on Friday. No, it won't be an RE-13 this time around... :P
PostPosted: Wed Jun 08, 2005 11:34 pm
RE-14?
PostPosted: Thu Jun 09, 2005 7:02 am
big willy wrote:
RE-14?
Nup... it's his`282' 8)
Same as what's in the 1330 8 porter, on his engine dyno this weekend.
PostPosted: Thu Jun 09, 2005 10:11 am
in this order
straighthrough xzorst
extractors
bigger carby
modified camshaft
modified cylinder head
PostPosted: Thu Jun 09, 2005 9:13 pm
Hmmmm - lets see...
20 thou over
202 head, hardened seats and larger valves with double springs
1.5 rockers(1.48:1 to be exact)
longer duration cam(no more lift = spring bind = boom boom!!)1100 sprite
maniflow small bore LCB
Lukey muffler
leckkky fuel pump(OEM about to be turfed for a Facet 3psi)
DHLA 40 carby jetted slightly rich
Morrie 1100 radiator to keep it all cool
running Vortex 98ulp plus flashlube
and a partridge in a pear tree
Gives me 50+hp and lots of fun with drum brakes on all corners!! It is a real bitzer!!
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Thu Jun 09, 2005 10:46 pm
1098 Crank also :wink:
998 Block with a 1098 Cranks = 1098
