It is currently Fri Aug 22, 2025 2:08 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 557, 558, 559, 560, 561, 562, 563 ... 568  Next
PostPosted: Sun Mar 03, 2019 7:49 pm
try stopmasters at brendale
been doing boosters for years
PostPosted: Sun Mar 03, 2019 7:53 pm
Be prepared to pay so big $'s for a Lockheed overhaul.
PostPosted: Sun Mar 03, 2019 7:59 pm
I tried to overhaul mine. Totally failed :oops: Sent the whole lot to the guy in Echuca. Now works like a charm.
A man's gotta know his limitations :P
PostPosted: Sun Mar 03, 2019 8:14 pm
Overhauled a VH44 in January, parts were around $150. Installed in car working fine. Have another VH44 to do, it's dismantled, just needs reassembly.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Mon Mar 04, 2019 7:53 am
Yes...so consider buying a new replacement :idea:
PostPosted: Mon Mar 04, 2019 12:41 pm
A major cost was sleeving the main bore. The air control bore was also sleeved larger to accept the VH44 piston as Lockheed parts for it are rare.
The main pushrod also rusts under the chrome.
PostPosted: Mon Mar 04, 2019 7:14 pm
Milatsmadmini
A pretty productive day, took the rear windscreen out, made a new parcel shelf, changed rear pop out window seals, painted a door or 2...
And finished up for the night with a rear windscreen around 90% in... How does one finish it? Is it a case of getting a strong wire, pulling screen down while pushing inwards?
Sent from my Pixel using Tapatalk
PostPosted: Mon Mar 04, 2019 7:45 pm
I've always had the help of a friend to install screens, one person inside and one person outside. Once upon a time, used to use thin rope looped in the outer groove of the seal to hold the seal to the screen. Fit as much screen into its proper place from the outside, then from the inside pull the seal inwards using the rope. Last time I fitted screens, I used whipper sniper cord, seemed easier. Probably doesn't help if you have the screen partially in. Also have had a bad experience trying to pry the seal in using a metal tool, broke screen. Safety glass breaking makes a mess. Use black silicone sealant as necessary, much better than the old black stuff.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Tue Mar 05, 2019 4:24 pm
Milatsmadmini
Windscreen in by myself! I'm going to cut someone if they ask why I'm still trying to get this locking strip in though....
PostPosted: Tue Mar 05, 2019 4:57 pm
Well done, locking strip requires the tool, or make one out of coathanger wire. Use WD40 and lots of elbow grease.
Good luck.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Tue Mar 05, 2019 8:01 pm
Try the slightly modified bulldog clip, worked a treat for me.
viewtopic.php?f=2&t=96127
PostPosted: Tue Mar 12, 2019 4:29 pm
I finally got back to putting my engine back together and noticed I am missing something! (I remember taking it out but I don't remember where I put it)
I feel like it's for oil, it had a spring and a bearing in it... but I can't seem to find what I need to order again!
PostPosted: Tue Mar 12, 2019 4:42 pm
Yep...Oil Pressure Relief Valve...a cylinder of metal and a spring. If you can't find it, buy or just look for another...
PostPosted: Tue Mar 12, 2019 5:25 pm
9YaTaH wrote:
Yep...Oil Pressure Relief Valve...a cylinder of metal and a spring. If you can't find it it, buy or just look for another...
Winner winner ! I don't know why I feel like there is another oil pressure relief valve (like behind the filter head?) but I assume there is only one. Off to the shops I go!
PostPosted: Wed Mar 20, 2019 5:46 pm
Attached chrome side strips, nearly finished, waiting on new carpet set.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
