It is currently Sun Jul 13, 2025 5:23 pm
PostPosted: Sat Sep 29, 2018 2:56 pm
I have some parts laying around and I think I will really have no use for them and no one else on Guam would need these because no other Mini on Guam. I was going to throw them away. Is there anything that you see that I should keep?
Thanks
Double leading shoe pair front hub
Pair rear brake drum with built in spacer
Remote box from the GT
1 1/2 intake manifold
3 to 1 pressed steel headers
AUS 29d distributor
1973 Clubman GT - YG2S8 1637
PostPosted: Sat Sep 29, 2018 3:14 pm
If you dont need or want them, or anything for them, just put them on here or gumtree as a lot lot for free- they could be of use to somebody!
PostPosted: Sat Sep 29, 2018 3:45 pm
Air filter housing
Elbow
Head light trim
No idea
Filters
Brake booster
PostPosted: Sat Sep 29, 2018 3:58 pm
The 'no idea' part looks like a heater air inlet for firewall.
PostPosted: Sat Sep 29, 2018 4:52 pm
Thanks I should throw all of these away soon unless I can give them to somebody or some are hard to find
PostPosted: Sat Sep 29, 2018 6:35 pm
Thanks I should throw all of these away soon unless I can give them to somebody or some are hard to find parts
PostPosted: Sat Sep 29, 2018 6:41 pm
I can't see any hard to get items. If you were selling these as a job lot in a large Australian city then you could get a couple of hundred for the lot. The postage will be a killer from Guam. Postage within Australia is not much better.
Drum brake parts are not wanted.
Spacer drums are $27.50 new so not worth paying the postage for used ones.
The remote change would be worth a bit if in good condition but its not a high in demand item.
Standard 1 1/2 SU metal airbox is something that is not asked for very often.
Standard 1 1/2 inlet manifold are not wanted.
People would rather buy an original Lockheed booster rather than the Bosch alternative.
The 29D4 with vacuum is not very popular.
If the extractors are factory original ones then they are worth a bit in good condition. If thin and rusted or with holes they are not worth much.
PostPosted: Sat Sep 29, 2018 7:29 pm
The only thing I think you should definitely keep is the gearbox remote - there's a possibility you'll need one in the future - slim, but possible.
I'd also keep the headlight rings, you might damage or lose one
PostPosted: Sat Sep 29, 2018 11:46 pm
Keep the original pressed seam extractors
Sent from my SM-G935F using Tapatalk
PostPosted: Sun Sep 30, 2018 8:29 am
Awesome responses I will keep the remote gear change and the extractors everything else will be thrown away. Thanks
PostPosted: Sun Sep 30, 2018 9:17 am
Online
Brake booster also used for Alfa Romeos so if anyone has an old one there, may need it or for parts...
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Sep 30, 2018 10:29 am
oops, missed that they were pressed extractors - keep them, send them to me maybe...
PostPosted: Sun Sep 30, 2018 6:03 pm
Take the ball joint pins out and keep the shims .
PostPosted: Sun Sep 30, 2018 6:11 pm
good one!! I do that too, though there is a pair of drum brake uprights in my trailer ready to go to scrap and I forgot all about it
PostPosted: Sun Sep 30, 2018 6:52 pm
I know what you're doing tomorrow :lol:
Users browsing this forum: BBY755 and 84 guests
