It is currently Tue Jul 15, 2025 2:39 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Ruby is hot
PostPosted: Sun Apr 01, 2018 6:39 am
When you say "back" I presume you mean the one on the end of the block hidden by the engine steady above the primary gear housing ?
PostPosted: Sun Apr 01, 2018 8:10 am
yep, that'd be the one Dr Mini is talking about... technically the front of the block is where the water pump goes, the left side of the block faces the grille and the right side is against the firewall
PostPosted: Sun Apr 01, 2018 12:19 pm
Simon you got the last statement arse about.;)
PostPosted: Sun Apr 01, 2018 12:40 pm
So the engine is described as if it was a north/south configuration as difined from the cars perspective
:wink:
PostPosted: Sun Apr 01, 2018 4:16 pm
Do I have my left and right confused again :? water pump against my belly button, left hand is holding the distributor, right hand is holding the exhaust manifold....
PostPosted: Sun Apr 01, 2018 5:31 pm
And you are looking from the LH side... When in car. Not how you described it above.
Left side of a north south motor is the exhaust side in car.
You are standing at the wrong end by convention.
