It is currently Sun Jun 29, 2025 2:09 am
 Post subject: Rev Limiter
PostPosted: Thu Jun 02, 2005 6:49 pm
Has anybody here tried fitting a rev limiter to their car? I'd be interested in fitting one to mine, I've had sticking throttles in the past and I don't want to damage my engine if it happens again.
I googled and found that Pertronix do one, but its a bit pricey - I would have though this would be the sort of item you'd find at SuperCheap?
PostPosted: Thu Jun 02, 2005 8:44 pm
isnt it that the valve bouncing stops the engine from reaching terminal velocity
PostPosted: Thu Jun 02, 2005 9:00 pm
piston thru block leaving big dent/hole in bonnet = rev limit reached :D
PostPosted: Sat Jun 04, 2005 10:48 am
Volkswagen Kombies have a rotor button with a spring loaded earth tab fitted,,,exccellent rev limiter & easy to fit to the Aust 29D mini distributor,,,easy-est & cheapest & most effective rev limiter ever made...piece of P!$$
I know everything don`t i ??? :-)
ok,,,maybe not everything :-)
PostPosted: Sat Jun 04, 2005 11:37 am
Here you go
http://www1.jaycar.com.au/productView.a ... &SUBCATID=
Chris
Everything I like is either
PostPosted: Sat Jun 04, 2005 10:21 pm
OT....
Obviously they didn't all get that, most 1500 Kombis had a vacuum governor..
I once worked on one which had it missing- and the owner had had the gearshift apart & f***ed it up and only had 1st & 2nd gear... he tried to drive it 30 miles to our workshop to fix, the motor over-revved, seized a piston & welded #3 rod to the crank. Nasty....!
But we fixed it. 8)
PostPosted: Sun Jun 05, 2005 3:58 pm
He he that sounds simple enough to work... now how do I set the rpm it works at? Would be really annoying if it cut the rpm at 4000 :)
PostPosted: Wed Jul 13, 2005 4:34 pm
http://www.proquip.com.au/ftdrl.html
Yum.!
More things to save for 8)
PostPosted: Wed Jul 13, 2005 6:41 pm
You forgot to say "easy peasy" :P
Just throwing another idea out there, you could control your ignition with a Megasquirt. You could rev limit with spark cut and have a fully programmable ignition map to boot. Though i'd say it would probably be the most difficult and time consuming way of doing it. Funnily enough I always seem to do things the most difficult and time consuming way :lol: :oops:
PostPosted: Thu Jul 14, 2005 4:37 am
Yum.!
Ooooh..that's nice..
PostPosted: Thu Jul 14, 2005 11:23 am
Its pretty expensive though.
But saves your engine... blah blah blah :roll: :)
The write-up always makes them sound good, and try to get you to spend money. I think its working. :x :lol:
PostPosted: Thu Jul 14, 2005 1:17 pm
OMEX (in engerland) have a model funnily enough called the clubman and it's ~$200
http://www.omextechnology.co.uk/page4.html
PostPosted: Thu Jul 14, 2005 4:54 pm
Yeah that looks cool... but if i were to get one i'd like to match things.
Pertronix ignition with Pertronix rev limiter.
Sounds cooler than
Pertronix ignition with Omex rev limiter :roll: :lol:
PostPosted: Fri Jul 15, 2005 11:14 am
so a clubman with a omex Clubman doesn't suit?
edit... the new signature's slick but aren't you getting a bit ahead of yourself?
PostPosted: Fri Jul 15, 2005 11:20 am
Rev limiter, pffft.. build it right & it won't matter! :lol: :wink:
