It is currently Fri Jul 18, 2025 7:58 am
PostPosted: Wed Sep 27, 2017 8:44 pm
I am a bit lost???
Is this the correct under bonnet insulation for a Mk 1 Cooper S?
If it is correct, I don't understand how it fits properly. There are no cut outs for the bonnet hinges, so I can't see how it goes in?
PostPosted: Wed Sep 27, 2017 8:56 pm
If you turn it up the other way, the rectangular cutout is for the master cylinders and the triangular cutout for the wiper motor.
PostPosted: Wed Sep 27, 2017 9:05 pm
Yes, but shouldn't there be cut outs for the bonnet hinges?
PostPosted: Wed Sep 27, 2017 9:22 pm
I suggest it is from a Clubman, which has the hinges on the outer edges.
It should also have a spot for the washer bottle for a Mk1.
PostPosted: Wed Sep 27, 2017 9:29 pm
Well spotted. I think you are right. :wink:
PostPosted: Thu Sep 28, 2017 2:27 pm
Shouldn't this be called firewall insulation, not under bonnet insulation?
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Thu Sep 28, 2017 2:51 pm
Also a flap cut into it so you can read the id tag
Plus it's a fine grain vinyl
PostPosted: Thu Sep 28, 2017 2:56 pm
A quick search will bring up several discussions on insulation, including firewall insulation.
See here - viewtopic.php?f=2&t=93337
Yes, Flute, that's the more appropriate term. Under bonnet insulation generally means the fibreglass stuff stuck under the bonnet.
PostPosted: Thu Sep 28, 2017 3:21 pm
8700s14 wrote:
I am a bit lost???
Just confirming once again that your photo is of the Clubman style insulation. I guess that's another item you'll need to source to maintain originality. :(
See here - https://minikingdomonline.com.au/produc ... bman-mini/
PostPosted: Sat Sep 30, 2017 7:41 am
Yes it’s a Clubman insulation pad and it’s firewall, not under bonnet.
71 Clubman GT
63 Morris 850
66 Mk 1 Cooper S
PostPosted: Sat Sep 30, 2017 9:18 am
Thanks for all the help everyone.
I will probably just modify it to fit for now unless an original is worth anything to sell?
PostPosted: Sat Sep 30, 2017 3:03 pm
I'd be interested if you wish to sell your Fire wall mat
Users browsing this forum: No registered users and 112 guests
