It is currently Sun Jun 29, 2025 6:22 am
PostPosted: Fri Jun 03, 2005 12:18 pm
Im sure someone here has replaced a floorpan in a mini before, I am just wondering if you can get them for a mini with fluid suspension, they have the channel down the middle and an extra rib. I have bought one for my 850 and it fits(no channel in 850), all the ones i have seen on ebay and the one i bought dont have the channel. If you cant get one for the hydro setup, is it possible to put the other one in. The ribs dont line up.
I have 4 minis and 3 have the drivers floorpan cut out ready to replace.
Steve.
PostPosted: Fri Jun 03, 2005 12:55 pm
Afaik you can't get them anymore in Aus. Please correct me if I'm wrong.
PostPosted: Fri Jun 03, 2005 2:21 pm
All the ones I've seen here are UK made, with no pipe channels as they didn't have them over there.
Also, they are a bit thinner than ours- when I did Anton's 850 the original floor was 1.6mm, the UK front pans I bought were 1.0mm.
Yes the ribs don't line up properly, even on the 850 shell. :cry:
PostPosted: Fri Jun 03, 2005 4:23 pm
Same problem here and its a pain in this ass :evil:
[Maverick] 1971 Mini K
PostPosted: Fri Jun 03, 2005 4:33 pm
Steve.
Steve...a car has just been cut up in Canberra for just that reason...looks like you need to find a donor shell (or three)... :idea:
PostPosted: Fri Jun 03, 2005 5:08 pm
You could replace all 4 pans, or get a whole floor? then clip the pipes and stuff on like early Mini Deluxe and Cooper S had. No channels in floor. :wink:
PostPosted: Fri Jun 03, 2005 8:38 pm
I had to replace both front floors on my 70 K sprint mini, used the ready available floor pans and had my friendly sheetmetal guy bend up some channels that I then inserted in the appropriate place in the floor. A bit of work but it worked. Stiffened up the floor too.
Steve
PostPosted: Mon Jun 06, 2005 8:30 am
Thanks for all the replys and ideas, i havnt had the net for the weekend so i have only seen them now. I guess i will try and find a shell to cut up, or maybe i will put the replacement panel in and just have them going along touching the panel, they have the cover over them so they should be ok.
Thanks again.
Steve.
PostPosted: Mon Jun 06, 2005 10:39 am
Well while were on the subject, does anywhere in Aus sell complete floor pans as opposed to 4x floor pan sections??
