It is currently Sat Jul 19, 2025 7:45 am
PostPosted: Tue Jul 25, 2017 8:35 pm
My son has a 76 Clubman where Im after some suggestions on a good needle size for his carby. Its a 998 with LCB extractors and the HS4 has a ramflo air filter setup. I tried the AC needle but as you would guess it was lean. I wound out the mixture nut about a turn and a half and the engine ran awesome except it ran way too rich at idle.
So can anyone give me some feedback on a needle suggestion to run with this setup.
Cheers Rob
PostPosted: Tue Jul 25, 2017 9:15 pm
Online
I have this kit with the AAU needle and is pretty good on the 998
http://www.minispares.com/product/Class ... STN17.aspx
PostPosted: Tue Jul 25, 2017 9:17 pm
Is that the floating needle Tim?
PostPosted: Tue Jul 25, 2017 10:27 pm
For a fixed needle try CP4. or no 6.
PostPosted: Wed Jul 26, 2017 7:21 pm
Thanks Dr I will check it out.
PostPosted: Mon Jul 31, 2017 7:16 am
Looks like CP4 is the one. The car ran so much better and it idled really well.
Thanks for your help.
Rob
PostPosted: Mon Jul 31, 2017 7:45 am
CP4 was the needle used in Police Cooper S with the twin HS4s and Ramflo filters.
I have used it in a few 998s and 1098s with a single HS4 and Ramflo.
PostPosted: Wed Aug 02, 2017 3:37 pm
Just about to fit twin HS4's to my new engine job. No idea what needles are in the carbs!
Thanks Doc for the heads up.
PostPosted: Thu Aug 03, 2017 6:24 pm
Try no 6 if CP4 too lean.
PostPosted: Fri Aug 04, 2017 10:02 pm
Decided to check what's there - AAK which, according to the no.s below look far too lean.
Thanks again mate.
AAK CP4 6
1 0.0890 0.0880 0.0890
2 0.0855 0.0852 0.0850
3 0.0830 0.0825 0.0814
4 0.0807 0.0790 0.0785
5 0.0784 0.0757 0.0755
6 0.0760 0.0725 0.0725
7 0.0735 0.0690 0.0696
8 0.0708 0.0655 0.0666
9 0.0677 0.0620 0.0636
10 0.0645 0.0585 0.0606
11 0.0613 0.0545 0.0577
12 0.0580 0.0510 0.0550
13 0.0550 0.0470 0.0520
14 0.0520
15 0.0490
16 0.0460
PostPosted: Fri Aug 04, 2017 10:23 pm
Looks like #6 is slightly leaner than CP4, I thought was richer. My bad, it's been a while since we sold Barney..
Check them on http://www.mintylamb.co.uk/suneedle/ it shows the differences well,
PostPosted: Fri Aug 04, 2017 10:36 pm
Sensational!
