It is currently Sat Jul 19, 2025 4:40 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 29, 2016 4:06 pm
gtogreen1969 wrote:
Can i trouble you for a photo of the battery cable clamps?
My power lead has a lug fixed to the end, not a clamp. I'm guessing the PO had some sort of power off switch between the lug and the battery itself. The negative has a standard braided cable.
PostPosted: Sat Oct 29, 2016 4:09 pm
Anything i do to my car i want to be as close to original as possible. Might just spend a few hours trawling through photos of boots. Its just hard to find unmolested cars to compare it to.
PostPosted: Sat Oct 29, 2016 8:36 pm
gtogreen1969 wrote:
Just trying to clean up a few items on my car back to original. I must admit I haven't really taken much notice of the battery cable routing in the past.
I have only recently noticed that my battery cable doesn't run up over the subframe like my clubby did. It is P clipped underneath at a sharp angle.
It may have been replaced in the past and it was too hard for the previous owner to re-route over the subframe in situ.
What is the correct way they routed the battery cable on a 68/69 Cooper S?
If it is supposed to go between the body and frame, and can this be done in situ or will I need to pull the subframe?
This is what it looks like.
This is what it may need to look like.
The second picture is correct , same as my Oct 1967 Mk1 .All the unmolested ones I have seen are like that , to allow the rear subframe to be removed easily
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sun Jul 09, 2017 12:20 pm
Original early 67 deluxe . Just for reference sake. 95% sure subby never been taken out .original battery cable was pulled off :)
Simonw
Brisbane QLD
- 1969 Mini K
 Post subject: Battery cable routing
PostPosted: Sun Jul 09, 2017 3:40 pm
Feb 66 Wheels Test shows what looks to be straight terminal at the non-earth battery terminal. Hard to tell, magazine pics are always grainy.
PostPosted: Sun Jul 09, 2017 4:34 pm
Thanks Phill. I have changed my thoughts on trying to keep it all original. Because I am not doing a restoration - anything close enough is good enough for me.
I just went with one of these.
Users browsing this forum: watsupskip and 69 guests
