It is currently Sun Aug 24, 2025 12:58 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 543, 544, 545, 546, 547, 548, 549 ... 568  Next
PostPosted: Sun Sep 18, 2016 10:55 pm
There were loads in Auburn Store. They are in Black packaging now so I was confused and couldn't find them as I was looking for blue! Only bought 3 as I can't fit any more in my garage. Next sale I'll buy a dozen or something.
Lillee - 1969 Morris Mini K
PostPosted: Mon Sep 19, 2016 7:07 am
Sold my first car and project 75 mazda 808 for 5.5k. Never got around to the nitty gritty being young and dumb. Reckon i just bought the mini a paintjob!
Sent from my SM-G900I using Tapatalk
PostPosted: Mon Sep 19, 2016 7:22 pm
Finally figured out my 12 month long wiring fail :D Very lucky nothing went wrong!
PostPosted: Mon Sep 19, 2016 8:16 pm
your running Lucas gear wow your lucky it didn't explode :)
1968 Morris Mini Cooper S
PostPosted: Mon Sep 19, 2016 9:41 pm
Managed to figure out how the rod change gear-selection mechanism under the gearbox mainshaft fits together - makes a Rubics Cube look simple :lol:
Curly
PostPosted: Mon Sep 19, 2016 9:55 pm
Found a heap more Cooper S parts I forgot I had in storage. Might be time to stop hoarding and cash in on some Cooper S inflation tax.
PostPosted: Tue Sep 20, 2016 9:09 pm
Susanna got her first full coat of Spray Putty today, after I spent two full days of the weekend sanding, filling and priming.
Later on I fogged over a coat of black "guide coat"
PostPosted: Tue Sep 20, 2016 10:10 pm
Subframe rebuild on its way! I love this bit , sooo satisfying . Had clean tap some threads on some the zinc coated bits.
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Sep 23, 2016 6:53 pm
Pressed a new stub axle in after i cut the old one up. The left hand thread threw someone off and the nut and bearing was smooshed.
Wasn't happy about it either
Did a new stud as well those things are tight as a drum!
PostPosted: Sat Sep 24, 2016 11:36 am
After a month overseas today I took the car cover off. With my skeptical friend looking on, gave the weber a few pumps and it fired up 1st crank. I love this car! :-)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Sep 25, 2016 12:04 am
A month? Pfft, I've gone 6+ months and she kicked over first time :wink:
PostPosted: Tue Sep 27, 2016 3:31 pm
I've done a couple of very easy things recently that made a huge difference:
Replaced the lockable fuel cap with the one you can get from supercheap. I filled up the tank this morning and it's passed the roundabout test with no leaks!
Replaced the old Britax seat belts with some modern retractable belts. They are much nicer to use :D
Fitted a proper firewall insulation blanket which has reduced the noise level inside.
PostPosted: Fri Sep 30, 2016 10:51 pm
Put this together.
Getting closer.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sat Oct 01, 2016 4:43 pm
Cut up/dumped a whole heap of parts. Tired of seeing them laying around. Not worth weighing them in with the current commodity prices
PostPosted: Sat Oct 01, 2016 8:26 pm
Couldn't have been mini parts, they're like gold!
