It is currently Tue Jul 08, 2025 6:17 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 541, 542, 543, 544, 545, 546, 547 ... 568  Next
PostPosted: Mon Aug 15, 2016 6:39 pm
Ordered electronic dizzy and stealth box. Took my timber dash down to a joinery to get a price on redoing it.
1968 Morris Mini Cooper S
PostPosted: Mon Aug 15, 2016 6:45 pm
Got my spare ready (need a bit more polishing) and made up a cover for it.
Eiles
PostPosted: Mon Aug 15, 2016 7:07 pm
Gearbox done
PostPosted: Tue Aug 16, 2016 1:15 pm
CPOCSM wrote:
Finally got the courage to attack the RHS fuel tank filler hole and cut the blasted thing out...drill...measure...grind...measure...grind more...insert tank...look...dremel grind...a bit more...snugs fit...grind more...nice even fit. Insert spacer, drill holes in back of seat, brackets in, straps attached, tank back in...forgot sturdy foam support under tank, refit and drill strap securing hole, weld captive nut in...voila. All done...
Tomorrow morning will run the hoses for the tanks. Thought about using the front cross brake line as a fuel line so will toy with that in the morning. Purists will hate me for it!
Hooroo
Ended up grabbing a length of bundy pipe at 5/16 OD and will suffice for the tube along the bottom front of the boot area. Will throw some rubber hose over the top of it to protect it and use rubber coated steel clamps to affix it...bit of overkill but will keep it tidy.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Aug 19, 2016 12:26 am
Got some new pipes delivered...
1978 LS 1275
PostPosted: Fri Aug 19, 2016 3:19 pm
Stuck my new sticker on
PostPosted: Fri Aug 19, 2016 8:02 pm
Re-did one side of the front suspension. Big day.
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Mon Aug 22, 2016 12:00 am
Made a rod change shifter fit a pudding stirrer Moke.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Thu Sep 08, 2016 10:57 am
I have flushed rusted water put 1 liter blue antifreeze in coolant system with fresh drink water today..
PostPosted: Thu Sep 08, 2016 11:56 am
Finished the rh tank install. Thanks Matt Read for the lh tank strap. Now just.to finish wiring and interior.
Rob Forsyth
Miniot!!
PostPosted: Thu Sep 08, 2016 2:24 pm
Don't forget the twin diagonal breathers Skills :idea:
PostPosted: Thu Sep 08, 2016 9:49 pm
All sorted there. T piece on LH hose and across the back of the seats and into the RH tank breather tube. Used 8mm screw in brackets with rubber protection to hold the breather up out of the boot. Have the rear boot board and brackets in this arvo and welding into place in the morning then a touch up paint of the boot in white goods POR 2 pack to tidy it up.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Sep 09, 2016 6:58 pm
big drums, flanges, new pads cyls and springs on. both fronts, torqued and greased! tomorrow is rear hilo's and flanges/drums.
PostPosted: Sat Sep 10, 2016 11:41 am
Tested 3 Mini Deluxe hydro bags, replaced hoses on 2 of em, filled with glycol and plugged with DrMini made plastic caps.
Just in case I need one... :)
Nooooo, the hose is not ye olde Dunlop Diamond, it is Pirtek MPH-06. rated @ 500psi WP.
PostPosted: Sat Sep 10, 2016 3:14 pm
You got me all excited that you'd found a source of supply for the proper hose, then a let-down. :cry:
Ah well, maybe someone someday will find it, or make it. There's a lot of displacers worldwide that could use it.
