It is currently Sat Aug 23, 2025 2:24 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 540, 541, 542, 543, 544, 545, 546 ... 568  Next
PostPosted: Fri Aug 12, 2016 8:21 pm
This thread is awesome, keep the inspiration coming!
PostPosted: Sat Aug 13, 2016 3:53 pm
New Moulder carpet
PostPosted: Sat Aug 13, 2016 4:16 pm
Very nice!
PostPosted: Sat Aug 13, 2016 4:36 pm
I took a video of my Clubman & put it on Instagram. That is the most I've done to it in months.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Sat Aug 13, 2016 5:59 pm
Cleaned, stripped and painted assorted brackets and fittings that will eventually be fitted to a customers '81 Moke following an engine rebuild.
Hanging them above a stoked-up pot-belly stove is the only way to dry things in winter down here :-)
Curly
PostPosted: Sat Aug 13, 2016 7:58 pm
Phil 850 wrote:
Where did you get the carpet from?
PostPosted: Sat Aug 13, 2016 9:47 pm
Queensland molded car carpets, now No Bull Accessories
https://nobullaccessories.com.au/produc ... e/leyland/
Brad Grieg is the guy I ordered through.
PostPosted: Sun Aug 14, 2016 8:13 am
Installed a power outlet so I can charge my phone etc. neatly tucked away under the dash shelf.
Also finished installing my top arm bump stops. started this job last year just before Rylstone and found that the old ones had been fitted with a bolt and nut!! For the life of me I can't see how anyone could fit the nut on the back of the bolt [rip Dad you were very determined]. I must be just as determined because I managed to finish the one I pulled off with about 10 hours to go till the start of Rylstone using wife's tweezers and little mirror I think. Anyway now they are SCREWED to the subframe.
PostPosted: Sun Aug 14, 2016 10:29 am
spent 7 hours with my awesome auto elec friend sorting the smoke filled wires out yesterday ..... why do people cock up wiring so bad ??
Another day to be spent on it next saturday then maybe just maybe it should be ready for it's rwc ... everything is crossed, not just my fingers.
PostPosted: Sun Aug 14, 2016 11:11 pm
Finally got the courage to attack the RHS fuel tank filler hole and cut the blasted thing out...drill...measure...grind...measure...grind more...insert tank...look...dremel grind...a bit more...snugs fit...grind more...nice even fit. Insert spacer, drill holes in back of seat, brackets in, straps attached, tank back in...forgot sturdy foam support under tank, refit and drill strap securing hole, weld captive nut in...voila. All done...
Tomorrow morning will run the hoses for the tanks. Thought about using the front cross brake line as a fuel line so will toy with that in the morning. Purists will hate me for it!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Mon Aug 15, 2016 8:26 am
Hooroo
Wouldnt brake line be a bit small??
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Aug 15, 2016 8:33 am
3/16" OD brake line is a bit small and won't fit 1/4" hose.
I used a length of 1/4" Yankee fuel hose instead. After 10 years it hasn't gone hard like cheap stuff does.
I ran it to a brass tee below the LH tank.
PostPosted: Mon Aug 15, 2016 4:23 pm
You must have used heaps of clips I'd imagine, wouldn't the hose sag otherwise?
I've been thinking of what to use to replace my fuel line, I'm going to try and find some 1/4" stainless tube
PostPosted: Mon Aug 15, 2016 4:37 pm
Found these on my desk...
1978 LS 1275
PostPosted: Mon Aug 15, 2016 5:14 pm
Found some.1/4 inch steel hose so using this instead. No the hose wasnt sagging but worried of damage being in the boot.
Rob Forsyth
Miniot!!
Users browsing this forum: Andosoft, slacko and 51 guests
