It is currently Mon Jul 28, 2025 6:05 am
PostPosted: Tue Jul 12, 2016 6:28 pm
Hi is any one running a maniflow twin su 1.5 steel manifold.
I am about to order one and was wondering are there any fitting issues and how is the accelerator cable mounted
Kiwiinwgtn
PostPosted: Tue Jul 12, 2016 6:55 pm
I have one but not yet fitted. They need to have something made up to mount the accelerator cable and also require bolts to attach your Carbs which could be welded in from behind for easier fitting or removal of your carbs
PostPosted: Tue Jul 12, 2016 6:59 pm
Thanks for the reply
Could you possibly post a picture I would be interested to know what angle the carbs rest at
PostPosted: Tue Jul 12, 2016 7:40 pm
It's currently with my engine builder so I can't get a photo sorry.
PostPosted: Wed Jul 13, 2016 8:17 am
Here is a couple of pics of mine when I had it off for a carby rebuild, hope it helps
PostPosted: Thu Jul 14, 2016 10:29 am
Here we go wellington kiwi,
The SU s are in need of an exterior polish but here are some photos etc.
I used an ITG air filter/ ram arrangement - quite low profile but WIDE -
the spacers were 16mm but when you put a gasket either side and a heatshield in there the 'space' is closer to 20mm.
the bottom of this heatshield where the return springs attach, is the part that wont slip down past the lip on the firewall, unless you tilt the motor forward...
The kit
Base of shield - linkage connector in the middle of the two SUs
From above
Nicely rounded entry for air
Cable attatchment and spacers
Cheers Darryl
PostPosted: Thu Jul 14, 2016 5:44 pm
Thanks Darryl exactly what I was after.
Would you be able to tell me what the distance is of A marked in my picture.
Thanks
Bernard
PostPosted: Thu Jul 14, 2016 6:13 pm
will do, when back at shed in the next couple of days
PostPosted: Thu Jul 14, 2016 7:38 pm
That's a lovely blue mat Darryl!
Steve
PostPosted: Sun Jul 17, 2016 9:43 pm
Hi , yes a blue car cover with a torana lurking underneath ....still. Makes a good background for all your good work!
Kiwi. The measure on top between flanges is 45-46mm. And the outer curve is 75mm
PostPosted: Mon Jul 18, 2016 7:54 pm
Thank you Darryl.
Its the same measurement as my one but it wont fit. I dont think my engine is tilted far enough forward.
PostPosted: Tue Jul 19, 2016 8:32 am
Do maniflow make an inlet for the spridget also..... that wouldn't need the same upward sweep and therefore make it harder to fit..... (just wondering if yours could be a different one?)
Users browsing this forum: JM1275 and 83 guests
