It is currently Tue Jul 15, 2025 6:16 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 5.5" x 10" wheels.
PostPosted: Tue Jun 28, 2016 10:09 pm
Well done, i applaud your efforts.
Assume they will be available through the usual mini channels here.
PostPosted: Tue Jun 28, 2016 11:09 pm
FNQ wrote:
bubbaclubby, by using a mini light or similar, the historic racers can and do use them.... being period correct looking( and again 5.5 inch is legal in Group Nb). Now a new design may or may not hit the fashion mark and be taken up by the general population, whereas everyone in a 50 year oldish mini knows the mini light look..... so i think it is a wise albeit slightly conservative move to stick to a known thing. Anyone doing their bit to keep minis running well ( and 5.5 inch rims are good for handling) deserves encouragement. Cheers darryl
Ok fair enough.... I just reckon there are enough companies producing mini lights..... There needs to be more options I reckon, or reproduce something rare from the period. My thoughts
But being made for mini racers I have no idea of the rules and regulations, so if it serves its purpose successfully well done.
Good luck.
PostPosted: Thu Jun 30, 2016 8:34 am
Will these be available through Performance Wheels?
PostPosted: Thu Jun 30, 2016 8:59 am
Will there be an option to buy them with some sort of centre cap?
PostPosted: Thu Jun 30, 2016 6:16 pm
I'd be interested in a set.
What's the price going to be?
Where can they be purchased?
Are pre-production orders being taken?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri Jul 01, 2016 9:35 am
Just so you know.
Mini & Moke World P/L hope to have stock of these wheels we have been helping design etc
due in August.
Will be available in silver & we have asked for them in charcoal too.
We have been pushing for these wheels to be made for more than a decade & finally
it has happened.
It covers the group Nb race cars & also the road cars as in theory we are only allowed to go
one inch over a standard 4.5 " cooper S rim.
It should fit both 145 & 165 tyres & you won't have the hassle of the wheel/tyre combination
fouling in the front under flair area due to the offset, unlike the current UK/Chinese 10x6" rims.
Thanks
AB
PostPosted: Fri Jul 01, 2016 9:52 am
Will these wheels fit under standard arches with cooper S discs? Or will you need to fit cooper s wheel archees or similiar?
PostPosted: Fri Jul 01, 2016 10:31 am
Yes will fit under morris mini or Leyland wheel arches.
PostPosted: Fri Jul 01, 2016 1:48 pm
miniandmokeworld wrote:
Just so you know.
due in August.
fouling in the front under flair area due to the offset, unlike the current UK/Chinese 10x6" rims......
How do they fit at the rear?? I have just found out that 165 Falkens fitted to LS style factory 10s rub badly on the shocks (even with S stepped drums).
Cheers, Ian
PostPosted: Fri Jul 01, 2016 2:34 pm
Ian I reckon it's just your tyres. Falken FK07E have a wider section width and baggier sidewall than any other 165/70-10.
Btw the 998LS only got 145-10s back then with your 10x5 wheels.
PostPosted: Sun Jul 03, 2016 11:45 am
Good luck.
Reproducing something rare may not make commercial sense, (economy of scale) as FNQ has said, the minilite style is a proven success and just looks right, on a mini! The final detail on these is IMO the best looking of this style. The best thing about this new wheel is its 5.5" tyre holding ability and lightweight. Also i think youll find the price very attractive!
The formula for the length of a piece of string is simple: Twice as long as from one end to the centre!
PostPosted: Sun Jul 03, 2016 11:51 am
Ryan
I understand they will be under $700 per set
I would recommend getting them from your preferred mini specialist if you want/need advice on your application.
No they will be in full producion and available soon.
Cheers Ben.
PostPosted: Sun Jul 03, 2016 12:04 pm
Cheers, Ian
These will fit pretty much any application on the rear.
These are the same width and offset as the ones i fabrictaed on my Nb car and I have spax shocks, minifin drums, (identical thickness to S cast iron) and even with a few mm toe out they dont rub. I have a few small rubber witness marks on the rear of the inner wheel arch but this would have been from 10 years of racing it on super sticky days (on hoosiers) cornering as hard as I can, so if you are going to exceed this tyre deflection then maybe a small 3mm spacer but I could never imagine anywhere near this on a road car. I have never marked a tyre or heard anything so this mark could have been caused by pickup running off the edge of the Hoosier or when I sometimes use 5" rims, that allow more tyre defletion.
Again consult your mini guy if you think you may exceed this grip and deflection and think this may be a problem?
cheers Ben
PostPosted: Mon Jul 04, 2016 9:39 pm
Ryan
Cheers Ben.
Apologies as it appears the pricing is not yet set on these wheels. It will be soon enough.
The intention is still to be less than most/all similar wheels currently available.
Cheers Ben
PostPosted: Fri Jul 08, 2016 9:25 pm
junior wrote:
Assume these are an alternative to the 5.5" wheels Dave Armstrong Motors have had made.
Here's another pic. Nice wheels.
It was interesting at Warwick last weekend that none of the Nb minis were running the Contessa wheels they traditionally run. I guess the risk of them cracking is too much these days. There were a few with these Dave Armstrong 10x5.5 wheels and the other cars were Nc class so they ran wider offsets.
It will be great to have another option for wheels when not running flares.
M
