It is currently Thu Jun 26, 2025 1:43 am
 Post subject: Morris into a mini???
PostPosted: Wed Feb 02, 2005 10:21 am
G'day,
Does anyone know if a morris engine(1275) fit straight into a mini (round nose)?
Mark
PostPosted: Wed Feb 02, 2005 10:53 am
The engine itself fits, I think the engine mounts have to be changed? the differences between the Mini 1275's and the 1100S 1275 in terms of what you want to do are insignificant.
I assume you mean an 1100S engine?
Not a Morris 1300 engine? - they can also be fitted, but I think need more work.
KB
PostPosted: Wed Feb 02, 2005 11:05 am
cool thanks, what about brakes? are they too big for a mini? the 1100s i'm looking at has disk breaks up front will they fit a mini?
PostPosted: Wed Feb 02, 2005 11:22 am
They aren't a straight swap. Different stud patterns, hubs and all the jazz.
Though you will need to fit discs with a 1275 by law.
PostPosted: Wed Feb 02, 2005 11:55 am
KB
1275 in line engine blocks (Midget, NZ Marina, etc) can be made to fit a Mini, but the rear main bearing needs to have the `seal' machined off it, and the crank swapped for a transverse one- Morris 1100S/1300, 1275LS, or 1275 Cooper S. That may mean the rods need swapping too. Hardly worth the trouble. :lol:
I did a 1098 AH Sprite one into a Mini once- these days it's not worth the bother.
