It is currently Thu Jul 17, 2025 5:05 pm
 Post subject: Hardy Spicer yoke ID
PostPosted: Sun May 15, 2016 12:29 am
Hi,
I have a couple of sets of Hardy Spicer slip-yoke assemblies and when dragging them out a few days ago I noticed that they are not all the same. The slip yoke body is a different shape, as is the flange that bolts to the diff drive flange. One pair uses external circlips to retain the uni cups, the other cups with c-clips on the inside. Splines and grease boot grooves all look to be identical.
One pair has 'Hardy' cast on one side and 'Spicer on the other, the other pair has something indecipherable in the same location on one side only. A part number maybe? At first I thought left and right sides must have been different, but now I'm figuring two pairs.
So does anyone know what either of them were originally from or whether it was a production change or whatever? Early and late production? Cooper and Matic? Mini and Morris 1100?
Don't listen to what I am saying... just understand what I mean.
 Post subject: Re: Hardy Spicer yoke ID
PostPosted: Sun May 15, 2016 6:52 am
I have never seen that other shape one on a Mini. However it is a Hardy Spicer standard design, off another car I believe.
Trivia- the spline inside an S yoke is the same as in the tail shaft u/J of a 1930 Austin Seven. :)
PostPosted: Sun May 15, 2016 11:46 am
morris 1300 is the other type
longer bosses where the eyes are for the u/j yeah?
easy-peasy :-)
PostPosted: Sun May 15, 2016 11:55 am
yep Morris 1300 alright. I gave a set to Fred Sayers years back. He uses them in is sports sedan minis
PostPosted: Tue May 17, 2016 1:23 pm
Thanks guys.
The 1300 ones look a bit beefier on first inspection. I'll have a closer look to confirm all the critical dimensions are the same including the boss length that Matt mentioned, but will probably look to sell both sets as I'll be using pot joints.
PostPosted: Mon Mar 18, 2019 1:35 pm
Long shot on old thread but can anyone confirm that these morris 1300 hardy spicers are ok to use on mini?
I have a set and am about to put a new engine in that came with them. The part number on the side is F1800R.
(Bulkier with circlip on the inside not outside)
rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Mon Mar 25, 2019 1:35 pm
Thanks to Mat the mini man for info on these. What a great guy keen to share his info with all.
These 1100 hardy spicers are too long to fit in a mini. They will bolt up but you need to cut too much of the driveshafts to negate bottom out inside the slip joint. Doesn't leave enough usable spline.
Ford DF LTD - 5Ltr
Users browsing this forum: Bing [Bot] and 87 guests
