It is currently Sun Jul 27, 2025 8:07 am
 Post subject: Washer bottle bracket
PostPosted: Wed May 04, 2016 3:01 pm
Could somebody please let me know the correct fasterners to hold the windscreen washer bottle retaining bracket to the firewall. During the repaint we inadvertently filled the holes. I assume self tappers?
Thanks in advance.
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
PostPosted: Wed May 04, 2016 3:17 pm
Thanks in advance.
Phillips head self tappers like this.
PostPosted: Thu May 05, 2016 7:15 am
Thanks
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Thu May 05, 2016 7:29 pm
I know that picture :)
PostPosted: Thu May 05, 2016 7:35 pm
It was the easiest one to borrow.
PostPosted: Thu May 05, 2016 7:39 pm
yeah all good, I dont mind, if it helped someone im happy
PostPosted: Fri May 06, 2016 2:04 pm
Washer bottle brackets fixed with 2 metal thread screws spring washers and nuts. Holes are too big for self tappers. Parts list gives screw as PMZ0308 which is zinc plated pan head Number 10 x 1/2inch.
PostPosted: Fri May 06, 2016 3:44 pm
My 69 S has small holes and self tappers. No visible scratch marks around the holes from any washers or nuts. I cut up an 850 shell a few months back and it had self tappers. I remember having to get the impact screwdriver onto it because I wanted to keep the washer bottle bracket. Maybe the CKD cars had the screws and nuts. The UK cars have a screw, 2 washers and a nut listed as the fastener. http://www.somerfordmini.co.uk/eshop/in ... page&id=82
PostPosted: Fri May 06, 2016 3:55 pm
My 68 Deluxe was definitely 2 self tappers.
PostPosted: Fri May 06, 2016 3:59 pm
Ditto my 67 Deluxe
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri May 06, 2016 4:47 pm
Maybe they did it two different ways. My '68 S has two self tappers.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri May 06, 2016 4:51 pm
I went to a mini 850 that was a wreck but very origional, the owner gave me the washer bottle bracket & it had never been removed. It was held on with two self tappers.Cheers.
PostPosted: Fri May 06, 2016 5:47 pm
66 deluxe and 67 mk1 S both 2 x self tappers
Rod
PostPosted: Fri May 06, 2016 5:50 pm
I am fairly certain the 62 850 I wrecked earlier this year had this.
PostPosted: Fri May 06, 2016 6:50 pm
I have some considerable stocks of the original self tappers used in all the vehicles I have been associated with.
