22A62 850cc - Early type with oil feed for primary gear, 1.375" dia. tail 22A63 850cc - Early type with oil feed for primary gear, 1.375" dia. tail 22A298 850cc - Early type thin-nose crank, 1.375" dia. tail 12A670 850cc - Later type with 1.5" dia. tail 12A298 997cc - Original Cooper crank 12A375 997cc - Cooper crank with oil feed hole for primary gear 12A595 998cc - Early EN16T spec 12A1451 998cc - Later, pre-A+ EN16T spec BHM1436 998cc - A+ spec, 1985 onwards (12A1451 forging) 12G82 1100cc - Standard across the board transverse A-series EN16T spec AEG330 970cc - EN40B forged, non-cross drilled AEG171 1071cc - EN40B forged, non-cross drilled AEG315 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, non-cross drilled AEG316 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, non-cross drilled AEG479 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, cross drilled AEG480 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, cross drilled AEG623 1275cc - Cooper S, EN16T forging, Tuftrided, 1.625" dia. big ends 12G1287 1275cc - Non-S, EN16T with 1.625" dia. big ends 12G1288 1275cc - Non-S, EN16T with 1.625" dia. big ends 12G1505 1275cc - Non-S, EN16T with 1.75" dia. big ends 12G1683 1275cc - 12G1505 forging, non-S, EN16T with 1.75" dia. big ends, Tuftrided CAM6232* 1275cc - Rolled-fillet radius on bearing journals, A+ with 1.75" dia. big ends
_________________ 120bhp with 450kg just fun waiting to happen
