It is currently Tue Jul 29, 2025 12:38 am
 Post subject: Chassis number
PostPosted: Thu Apr 28, 2016 9:41 pm
Hey guys, I have a question to throw out to you:
The chassis number on my Mini is unfortunately rubbed out, you can only make out some of the numbers.
What would you suggest to use / do in order to bring the full chassis number out again?
Many thanks. [THUMBS UP SIGN]
 Post subject: Re: Chassis number
PostPosted: Thu Apr 28, 2016 10:04 pm
Heat with a oxy or similar, remove the paint with a wire brush. Then heat up the numbers until you can read what they say. It's like a tattoo, you can still read them when there heated although you can't when it's cold.
Good luck
Daniel
PostPosted: Thu Apr 28, 2016 10:14 pm
That's a bugger. I have seen so many cars that have been butchered and given a new chassis number. Is yours restamped with a NxxxxxP number?
I used battery acid and wet and dry sandpaper on my engine block but I haven't tried it on a body number.
If yours is a 1969 car you should also have a number stamped into the drain gutter above your wiper motor. 2/06 and a 3 digit number .
Like this
PostPosted: Fri Apr 29, 2016 1:00 pm
Cheers - I'll have a look next week when I'm back home. I'm pretty sure it's a 69 model.
Users browsing this forum: Bing [Bot] and 79 guests
