It is currently Tue Jun 24, 2025 4:31 am
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 15  Next
PostPosted: Thu Apr 14, 2016 12:24 am
From what I have read, the Honda engines are about 50kgs heavier. I have the weights before the project so will find out after. Hopefully after removing all the stuff I don't need from the B16 and adding the required hybrid gear in it should balance out or increased by less than 50kgs.
There is no plans to change the coils i have in it. They are road race. I may have to raise it a little to allow for the additional weight.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Thu Apr 14, 2016 12:08 pm
Thanks for the info. :D
Maelgwn
Maelgwn No Mini Yet :(
PostPosted: Mon Apr 25, 2016 11:10 pm
RH fuel tank in and the joy of wiring has begun.
1961 Morris mini
PostPosted: Mon Apr 25, 2016 11:29 pm
Yep the wirings a fun job. :?
Whats the wiring for your engine? Have you bought a minitec / rywire loom or using an OEM honda one?
PostPosted: Mon Apr 25, 2016 11:36 pm
OEM Honda engine harness, then Honda harness from engine into firewall then a couple of multi pin plugs connecting it to the ECU and dash cluster. Original mini wiring still remains for front lights etc.
1961 Morris mini
PostPosted: Tue Apr 26, 2016 3:35 pm
Nooooooo! Not Lucas wiring!
Even if you run them in the same location as the old wires, please replace them. It'll save you upgrading the headlight wires later if/when you get the drop-in halogen headlight conversion too. If nothing else, do it just to get rid of those bullet connectors to have blade terminals instead! :)
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Tue Apr 26, 2016 5:08 pm
I already have the halogen headlights and it's been fine. I don't like any of the mini wiring to be honest but to replace it all is another project for another time. Thanks for the feedback though.
1961 Morris mini
PostPosted: Sat Jun 04, 2016 7:47 pm
Bit by bit it is still coming together......slowly.
After reviewing the feedback on Ausmini and other forums I decided to modify the accelerator pedal to reduce that on/off switch feeling that people are talking about. I took an inch out of the top and added it to the bottom and raised the mounting point.
I extended the short shift Honda gear lever and installed it for the last time. Hopefully.
Radiator, wiring and a few other bits and pieces installed.
I also purchased a set of minivation bonnet hinges to make it easier to work on the car in the future without removing the bonnet.
It's off to get the exhaust done now.
1961 Morris mini
PostPosted: Sat Jun 04, 2016 9:22 pm
In terms of the hinges, you may need to tighten, test, then twist the back side bolts down.
Nick
PostPosted: Sat Jun 04, 2016 10:56 pm
ok. I haven't installed them yet so will keep it in mind.
1961 Morris mini
PostPosted: Tue Jun 21, 2016 1:12 pm
Hey Dutchy, what's the latest on the build?
Zulu...
1967 mini Cooper S
PostPosted: Wed Jun 22, 2016 8:24 pm
As my engine was so far forward I had to get the exhaust custom made from headers right through. Garry & Dave from TruFit Exhaust in Moorabbin (Vic) were extremely helpful and well priced too. I picked up the car today and there was a nice blue Vtec Moke getting an exhaust done too. Who would have thought.
The headers were made in two pieces to allow for easy removal. I also had them wrapped to protect the front grille and paintwork from the heat.
It then flows to a collector with 02 sensor, Flexi joint, custom cat, resonator then to the straight through Playmini muffler. I'm looking forward to hearing it when it's up and running.
1961 Morris mini
PostPosted: Wed Jun 22, 2016 9:05 pm
very tidy work, looks great
PostPosted: Thu Jun 23, 2016 8:27 am
That looks amazing. Loving this thread more and more.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Thu Jun 23, 2016 9:32 am
When thats running put the exhaust on youtube PLEASE!!!!!! we want to hear it, Shame you had to wrap the pipes though
