It is currently Tue Jul 29, 2025 12:40 am
PostPosted: Sat Apr 23, 2016 1:38 pm
Gezo - PM sent.
PostPosted: Sun Apr 24, 2016 7:34 pm
winabbey wrote:
gtogreen1969 wrote:
Am i reading it correctly that the position of the car number is the L.H valance radiator cowl from YKG2S2 5393?
That's what it says, and I've no reason to doubt it happened in practice. Always happy to see any evidence to the contrary regarding these factory documents. :)
PM Sent
PostPosted: Mon Apr 25, 2016 3:03 pm
I've been advised that there are several cars with factory fitted ID plates after car 5393, so practice and theory are not in alignment on this occasion. It begs the question as to whether the YKG2S2 nnnn code was stamped in the shroud for cars after 5392 that still had an ID plate.
PostPosted: Mon Apr 25, 2016 10:11 pm
There is still a half entry with missing info that has same body number as my Mk 2 ?
Not sure where the other partial entry and data came from but I'm happy for anyone to verify my S and body number.
Mini's I grew up with
Slot car couch
PostPosted: Mon Apr 25, 2016 10:31 pm
I noticed that double up.
You have a very clear 1210 2/06 on your gutter so its probably a typo for the other car. Not to mention your car is a very good example of an unmolested car.
PostPosted: Tue Apr 26, 2016 9:43 pm
My car YG2S4 836 has body number 332 and so does car YG2S4 837? I know mine is correct so maybe they made a few mistakes along the line?
Rod
PostPosted: Wed Apr 27, 2016 9:08 am
Thanks everyone for the feedback on wrong or missing numbers. Bit by bit we'll cleanse the data. :)
PostPosted: Wed Apr 27, 2016 11:10 am
Rod
When I said "they" I was referring to the factory
PostPosted: Wed Apr 27, 2016 11:34 am
rodmac wrote:
Rod
Of course that's possible, Rod, but I reckon the body numbers would be unique and correct as this number was used to keep track of the car is it went through the production line. If there was a duplicate I think it would've been picked up and corrected early on. Since the body number wasn't meant to be seen or used once the car body was assembled and ready for paint it's more likely that numbers quoted in the register have been misread by an owner.
Here's what Peter Davis says about the Body Number:
SMBD Body Stampings
Bodies were stamped with a code by the Sheet Metal and Body Division at the end of the metal finishing line for internal tracking and a running cumulative total. The number was used within the body shop and not intended to be visible on the completed vehicle. It was positioned in diverse places, sch as (depending on the vehicle) the battery tray platform, bulkhead drain channel, behind the voltage regulator, or behind the final ID plate or compliance plate position.
