It is currently Tue Jul 29, 2025 6:22 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Gearbox question
PostPosted: Fri Apr 22, 2016 10:25 pm
Pottsy,
How about "W" for Weslake, the original head designer, IIRC, way back when you and I were in short pants????
RonR
68 build Mk1 Cooper S
PostPosted: Fri Apr 22, 2016 11:35 pm
It could well be the "M" for MOWOG stamped on the head
PostPosted: Sat Apr 23, 2016 8:12 am
That 12G1316 head is just the 'smog' head with air injection into the exhaust ports. Used on all 1275LS, and late 1275 Moke. Valves are same as an 1100S.
PostPosted: Sat Apr 23, 2016 1:41 pm
The Mini King
Pottsy wrote:
Hi guys. I've been loaned a 1275 motor and gearbox to get my Mini back mobile after a crank meltdown in my old (but really new- long story!) motor.
It's a 12H902UH prefix motor on a gearbox casing number DAM2886.
Allegedly, since it came with the rest of the car, it's from a 1977 Moke Californian, also allegedly with only 53,000 odd km on the clock.
The lender is pretty sure it has a 3.444 diff in it, but I find that a bit hard to swallow given the 12 (or 13) inch wheels on a late Moke. I don't intend changing my Deluxe from the 10" ones.
If it has that diff, then I'll try it as a unit, otherwise I need to swap gearboxes, which I'd rather avoid if possible. Equally, if what I've read on the odd pommy forum is accurate then it may well be an early A+ box which would perhaps mean all sorts of mismatches with drop gears and idler bearings I believe.
Is anyone out there able to enlighten me please as to the likely diff ratio without me resorting to stripping the thing? Needless to say, the sticker showing the ratio, that occasionally survives on diff housings, is long gone.
I await input with a mixture of hope and trepidation! :)
Cheers, Pottsy
With The info you gleamed from the below, and With a DAM2886. gearbox case number,
you can be sure it will be the large idler gear model.
PostPosted: Sat Apr 23, 2016 4:19 pm
Thanks guys for all the valuable input.
I've removed the diff and it's a 4.27 unit. (22G370, 15/64)
I've got the 3.44 from another gearbox which was already fitted with new bearings, pin and spider gears so that looks like it'll go in with no problem. Assuming the diff bolts in as a unit, and the pinion fits nicely on the shaft, then all of the potential mismatches are avoided neatly. Fingers crossed but there appears to be no difference in the differentials that I can see as far as bearings etc.
The output bearing carrier now visible through the end cover removal is one of the nominal later units with the 4 bolts, so I think the diagnosis of an early A+ box, at least, is spot on.
As far as the head detail is concerned, that sound you could hear was me smacking myself on the forehead when it was pointed out that it was 12 G 1316 and not 12 0 1316. I should have sussed that. Doh!
Just got to make some 7/16 UNF plugs for the head and we will progress nicely.
Thanks for all the help so far. Since this is my first foray into the mystic world of Big Bore Engines, I daresay there'll be a few more odd queries at times. I appreciate the feedback.
Cheers, Pottsy
Smile Up at The Trucks!
PostPosted: Sat Apr 23, 2016 4:32 pm
A cheap way to plug those 7/16 unf air ports is use old seat belt bolts. Then cut em off and grind smooth.
Users browsing this forum: Majestic-12 [Bot] and 86 guests
