It is currently Mon Jul 28, 2025 9:15 am
 Post subject: Wide numberplate flap
PostPosted: Thu Apr 21, 2016 2:33 pm
Just wondering what people use to secure their number plate
to the flap on early cars. Should there be holes or not.
Notice on mine no holes and really no way of securing except for double
sided tape which I've used.
PostPosted: Thu Apr 21, 2016 5:44 pm
that's a bit odd! surely someone would have drilled holes in it at some point over the last 50 years!
PostPosted: Thu Apr 21, 2016 5:46 pm
oh look, here's one - you can see the old drilled holes and the new little plate with cable ties (pinched from the latest post in what did you do on your mini today thread)
PostPosted: Thu Apr 21, 2016 8:30 pm
I need to figure out a more elegant way to hold the plate on and hide the old screw holes... It was previously using self tapping screws
PostPosted: Fri Apr 22, 2016 7:58 am
I plugged all the old holes before painting, then used 4 tamper proof screws & nuts on my historic plate.
It now has custom Bling frames made from tile edging (4 pcs mitre cut).
PostPosted: Fri Apr 22, 2016 8:47 am
This is my style.
The large backing plate is the same size as a standard ACT number plate. The historic plate is held on with Sikaflex 11FC, and the four screws are dummies.
PostPosted: Fri Apr 22, 2016 10:24 am
This is my style.
I was thinking of doing something like this. Did you make the backing plate or buy it? I was thinking of getting something neatly cut.
PostPosted: Fri Apr 22, 2016 11:05 am
You can get after market number plates made up, so I've been thinking of getting a full size one in white with no characters on it, and doing something similar to DavidE above. That way you'll have the nice stripe around the outside.
UK sizes to suit early 850
http://www.ebay.co.uk/itm/PRESSED-ALUMI ... xyRNJScuxB
These are Aussie size
http://www.ebay.com.au/itm/Custom-Novel ... SwKtlWltrF
PostPosted: Fri Apr 22, 2016 11:43 am
This is my style.
The set on one car was made for me out of stainless steel, but the one/s in the picture I made myself out of aluminium sheet, cut to size and I rounded the corners using my vertical linisher. I have a spare and surplus set in stainless steel.
PostPosted: Fri Apr 22, 2016 6:46 pm
You can try double sided tape or Velcro!
"Let us remove your "SHORTS"
PostPosted: Fri Apr 22, 2016 6:55 pm
No, I did not.
PostPosted: Sat Apr 23, 2016 10:38 am
+1 for double sided tape. I know plenty of cars that have number plates held on with double sided tape. But don't use too much because then that is annoying if you need to remove the plates.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Sat Apr 23, 2016 11:40 am
Thanks for the response guys. I guess the double sided tape will do for now since it doesn't go too far
PostPosted: Sat Apr 23, 2016 11:43 am
Just think about how much you use though. Too much and if it's strong you might bend the plate if you ever need to remove it. Too little weak it might fall off.
PostPosted: Mon May 30, 2016 11:20 am
I ordered some UK size plates from eBay. They were just under $40 delivered for the pair, and they came with some double sided tape, and also some security screws. They are exactly the right size to surround the Historic plate.
I've got them held on temporarily at the moment, but they look much better than all the holes showing on the flap. I've just got to decide if I use the double sided tape or the security screws (and what do to about the front plate too).
Users browsing this forum: No registered users and 21 guests
