It is currently Tue Jul 29, 2025 6:34 am
PostPosted: Wed Apr 20, 2016 2:54 pm
Putting my 997 together and i have a question regarding the regulator wiring, my new loom has the regulator wiring branching from the main harness at the firewall, it then has to run under the fuse box, seem odd to me???
Any pics of original spec setups?
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
PostPosted: Wed Apr 20, 2016 4:02 pm
The only reason i can see why they would split the loom at the firewall is if the generator was mounted like the Cooper S. Is that a generic loom to fit both Cooper and Cooper S?
PostPosted: Wed Apr 20, 2016 4:29 pm
Yes, but clarity is a real issue.
Aren't those loose wires for the back end of the fuse block?
The regulator wires should come from the harness after it emerges from the hole in the bracket adjacent to the regulator, so they attach directly to the terminals of the regulator.
PostPosted: Wed Apr 20, 2016 4:44 pm
I have my original 997 harness on the shelf will look soon
PostPosted: Wed Apr 20, 2016 5:06 pm
Thanks
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Wed Apr 20, 2016 5:08 pm
No from Vinwire and is supposed to be for 997 Cooper
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Wed Apr 20, 2016 5:09 pm
Yes, those loose wires are for the fuse block, I just havn't installed it yet.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Wed Apr 20, 2016 5:27 pm
Just checked would branch at the gusset not the bulkhead like the new one
And the new one I put in it is correct to
PostPosted: Wed Apr 20, 2016 6:06 pm
Where a the wires for the regulator, then?
PostPosted: Wed Apr 20, 2016 6:23 pm
The second braided loom going through the gusset
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Wed Apr 20, 2016 6:24 pm
Any chance of a picture? Looks like I will need to remove it and send back for modification.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Wed Apr 20, 2016 7:23 pm
From the picture it seems to have a big harness loop behind the Gusset . I might be wrong but is the loom fitted correctly or does it need to go further foreward?
"Let us remove your "SHORTS"
PostPosted: Wed Apr 20, 2016 7:52 pm
Will get it tomorrow
PostPosted: Wed Apr 20, 2016 8:10 pm
I got this one for my 997 Cooper , haven't put it in yet , will get a pic tomorrow
http://www.somerfordmini.co.uk/eshop/in ... ts_id=4062
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Wed Apr 20, 2016 9:21 pm
[youtube][/youtube]
It's in the correct position, the earth wires are bolted to the gusset, and the fuse box wires are in the correct location, plus everything else lines up fine.
1964 Sunbeam Tiger
1969 Austin 1800
