It is currently Tue Jul 29, 2025 5:55 am
PostPosted: Thu Apr 14, 2016 11:30 pm
Hi Everyone,
Long time lurker, looking for some advice.
I have a mk1 1098 mini deluxe with a clutch issue.
Clutch won't disengage.
The operating level is easily moved forward by hand. But only back and forth, it is not loose like it has 360 degree movement.
Is this a release bearing?
A local mechanic has advised me to remove the engine so they can do the clutch repair. Is this correct?
Appreciate any advice here.
Thanks,
marks.
2009 Mini Cooper JCW - Roger
1967 Mini Deluxe Mk1 - Ruby
PostPosted: Fri Apr 15, 2016 6:19 am
I would first remove the clutch lever and check to see if the ball hasn't broken off where it engages the release bearing plunger. This is an easy job and can be done without removing the engine. A broken lever is a common fault.
PostPosted: Fri Apr 15, 2016 6:20 am
It could be the arm has the ball broken off the bottom, or just lack of travel due to wear, or worn seals in the MC or slave cylinder.
If it's the release bearing it will be noisy when pedal is down.
There is no need to pull the engine out, the whole clutch assembly including flywheel can be removed in the car.
Take it to a Mini mechanic that knows what he's doing..! there are a few in Brissy.
PostPosted: Fri Apr 15, 2016 7:13 am
Thanks for that.
The hydraulics are fine. It is whatever is pushed by the lever has gone. It went slowly (harshly got harder to change gears), which is why I thought the lever would be ok.
Does the fly wheel need to be removed to get to this assembly? Or to get to the bearing"?
Any recommendations on mechanics in the western suburbs works be welcome.
I used to use a guy on blunder road but he he's moved on from there.
Thanks.
PostPosted: Fri Apr 15, 2016 7:41 am
To pull the clutch arm out, remove the clip and the big lower pivot pin. It will then pull out.
To do the release bearing, undo the drivers side engine mount, then jack under the sump on that side. Remove all the bolts in the clutch cover aka `wok' and it comes off, with the release bearing. Remove starter first.
No need to pull the flywheel unless the clutch needs work. For this you need a Mini flywheel puller.
PostPosted: Fri Apr 15, 2016 4:27 pm
there are 2 big nuts on a thread that should move towards the motor when you pull the lever towards the mudguard... do they move?
PostPosted: Fri Apr 15, 2016 9:03 pm
Sounds like broken ball. I've had one break and somtimes it just gets worse as it's going. In fact with lots of adjustment I limped home with one that was snapped. The broken end was still operating the clutch[FLUSHED FACE]
PostPosted: Fri Apr 15, 2016 9:52 pm
Thanks for the advice. I'll go and pick it up over the weekend and get it home.
Is it right if I pull the lever out (to check for wear or missing ball end) I can do that without removing the wok cover?
Cheers.
PostPosted: Fri Apr 15, 2016 9:55 pm
Cheers.
Yes it is
PostPosted: Fri Apr 15, 2016 10:30 pm
http://www.minispares.com/catalogues/cl ... spx?1~3~31
Check this pic:You need to look on the bottom of #27 for a broken ball.Disconnect spring #36, and pull out splitpin from pin #29 and then remove #27. look inside plunger #22 for broken ball. You may have to get a new #27 if it is broken. you can get a new one from:
http://minisport.com.au/mini-clutch-lev ... on-genuine
PostPosted: Fri Apr 15, 2016 10:38 pm
Check for wear inside #22 where the ball sits.
Beware, most cheap new ones are rubbish, they are made from soft steel and NOT hardened. So wear out in months, not years. Better ones cost more.
Try a file on its corner, if it cuts it, it is rubbish. Can be fixed by drilling out, then turning and fitting a hardened steel bush. But we shouldn't have to do this. :evil:
PostPosted: Mon May 02, 2016 3:49 pm
Hi All,
I got the lever out and attaching photos.
There is wear but maybe a 1mm off the end. Not a perfect ball but not far off.
Would this small amount of wear be the issue?
Regards,
Mark.
PostPosted: Mon May 02, 2016 10:48 pm
That arm has had it. Also look inside the plunger, I bet there is a groove worn in there where the ball sits.
If so, replace it too. And DON'T buy the real cheap plungers, they are so soft they wear out in 3 months. Cannot be hardened because of the material spec. Aftermarket `quality' parts. :roll:
Pack it with grease when you reassemble.
PostPosted: Tue May 03, 2016 8:13 am
i can help you if you`re stuck
Murarrie Bne
Matt
0407 135 656
PostPosted: Tue May 03, 2016 11:29 pm
Thanks Matt,
I'll get a new arm and plunger (and perhaps a bearing while I'm there) get that in and come and see you. I'm over the other side of Bris Vegas.
Side question. I need to replace the bushes in the control arm. My 67 mk1 uses the tapered ones?
Cheers.
Users browsing this forum: Bing [Bot] and 72 guests
