It is currently Tue Jul 29, 2025 6:31 am
 Post subject: Re: Unknown Switch
PostPosted: Mon Apr 11, 2016 10:35 am
shnitzee wrote:
Winabbey, do you have a copy of the separate radio booklet the operator's manual talks about? I'm after some details & diagrams so I can refurbish the radio correctly.
The only radio booklets I have are 1971 and earlier. In any case they wouldn't be much help to you as they are basically just a list of all the Australian AWA repair places addresses and phone numbers. Nothing about the radio operation itself or circuitry diagram. Maybe later versions were different.
PostPosted: Mon Apr 11, 2016 5:32 pm
shnitzee - the internal Leyland part number for the radio unit used in the Mini Clubman from around the end of 1972 is AYG9441, which is an AWA PG37Y. Your car may have a different model. I suggest you have a close look at your unit to see if there's any manufacturers model number. You could then search for relevant pictures and data.
Here's a link to the PG37Y - http://www.radiomuseum.org/r/amalgamate_pg37y.html
and a link to many AWA units - http://www.radiomuseum.org/m/amalgamate ... model.html
PostPosted: Mon Apr 11, 2016 8:28 pm
Thanks for the info Winabbey; much appreciated.
Eiles
PostPosted: Wed Apr 13, 2016 9:30 pm
Glad i didnt just rip it out now. Theres a lot of things coming off this mini in relatively good condition thag arent going back on. Sadly im gonna need new windscreen demister vents. They crumbled in my hands when i took them off...
Sent from my SM-G925I using Tapatalk
Why Drink And Drive When You Can Smoke Dope And Fly!?
