It is currently Tue Jul 29, 2025 1:27 pm
 Post subject: Engine storage
PostPosted: Thu Apr 07, 2016 9:59 pm
Hi: Done a search but can't see anything - if I have missed sorry. I need to store a complete power unit for a while, fully assembled including radiator. Any tips? Obviously fill the sump to the dipstick full mark - but what else? Fill the cooling system? Thank you
1965 Austin Cooper 998 (UK built)
1963 Austin Countryman woodie
 Post subject: Re: Engine storage
PostPosted: Thu Apr 07, 2016 10:22 pm
Block all holes up to stop wasps making nests anywhere they can
PostPosted: Fri Apr 08, 2016 7:52 am
Put a strip of cardboard instead of a manifold gasket, if carbs are on it.
Squirt some oil into all the spark plug holes then turn the motor over by hand for a turn or so.
PostPosted: Fri Apr 08, 2016 6:31 pm
Thank you
PostPosted: Fri Apr 08, 2016 7:20 pm
I would drain all the water... electrolytic action will continue if you don't....
..and how much is .."a while"... ?? Fresh oil and clean antifreeze is fine for 4 or 5 years..
You can buy special "fogging" oil for long term storage.
Cheers, Ian
PostPosted: Fri Apr 08, 2016 8:42 pm
I could store it in my mini and give it a run now and then, just to help you out.
