It is currently Tue Jul 29, 2025 1:24 pm
PostPosted: Tue Apr 05, 2016 2:01 pm
I have a 998 mini with a maniflow lcb. I bought a Sportex rear box from Minisport but it is far too loud.
I obviously should of got a twin box system.
My question is should I add another silencer to the Sportex or should I just replace with a more quieter system like a rc40 twin box or something similar?
PostPosted: Tue Apr 05, 2016 4:07 pm
I just added an $80 cherrybomb [[edit] hotdog resonator in the tunnel. Worked for me.
Last edited by drmini in aust on Tue Apr 05, 2016 10:53 pm, edited 1 time in total.
PostPosted: Tue Apr 05, 2016 6:12 pm
+1
A single box RC40 won't pass ACT rego checks but the twin box is fine.
I would look at the cheapest route to Kev's solution.
Cheers, Ian
PostPosted: Tue Apr 05, 2016 6:17 pm
Thanks. Is it much quieter now after fitting a cherrybomb silencer?
PostPosted: Tue Apr 05, 2016 6:39 pm
Still has a good note but the raspy bark has gone.
PostPosted: Tue Apr 05, 2016 8:48 pm
Would you consider the noise to be within the legal limit?
PostPosted: Tue Apr 05, 2016 9:50 pm
Yes. It is quieter than the Dellorto carby's induction noise now. :)
[edit] cherrybomb is an american term, it is actually a `hotdog' here. I picked the wrong word...
You can get them at any muffler shop, I welded mine in.
PostPosted: Tue Apr 05, 2016 11:01 pm
Ok cheers mate. What back box do you have?
PostPosted: Wed Apr 06, 2016 6:51 pm
I have a 2" system, the rear muffler is a diagonal pipe glass filled oval 'turbo' one.
PostPosted: Thu Apr 07, 2016 7:41 am
To get mine quieter I went to my local exhaust shop and told them I wanted it quieter - what did they have?
They went to their stock and found a muffler that would fit under the car and put it on. Hey presto the car sounds pretty good and is now not too loud.
Was cheap too. If I recall it was $100 fitted. I think you can muck around with RC40 and all the off the shelf mini shop but the best answer is go to your local and see what they can do.
Alec
PostPosted: Thu Apr 07, 2016 2:23 pm
Cheers Alec. I never thought about that. Certainly worth a try.
PostPosted: Thu Apr 07, 2016 7:16 pm
I did the same. I bought the 2" bore turbo muffler then crawled under the car and measured the pipe lengths needed, and angle (30deg).
I then went back to the muffler shop and got two 2" pipes cut and bent.
Crawled under the car again, fitted the muffler to the pipes and clamped them. Removed assembly and MIG welded the pipes in.
When later I fitted the hot dog in the tunnel, I did the same again. Cut the front pipe and MIG welded the hotdog in.
Note the 2" pipe was a slip fit over the Y piece of the Maniflow med bore LCB.
Users browsing this forum: Goldbrocade_62 and 115 guests
