It is currently Tue Jul 29, 2025 11:37 pm
 Post subject: What Tappet Cover?
PostPosted: Mon Mar 28, 2016 3:46 pm
Does the std Tappet cover fit over 1.5 roller rockers or do you need an alloy cover. This is on a 1275 Mk2 engine.
 Post subject: Re: What Tappet Cover?
PostPosted: Mon Mar 28, 2016 4:34 pm
Yes it should fit. Mine standard one fits over the MED 1.5 roller rockers that i have.
michael
PostPosted: Mon Mar 28, 2016 5:58 pm
Alloy covers are thicker material and so (generally??) smaller on the inside ...
My MiniSpares item needed a flycut to allow clearance for Titan 1.5 rollers....
Cheers, Ian
PostPosted: Tue Mar 29, 2016 9:25 am
Thanks for the replies. Mine are MiniSport, so I'll wait and see what happens on assembly. They look as though a std cover will be ok.
Alan.
PostPosted: Wed Mar 30, 2016 12:08 pm
The alloy cover fits over Yella Terra 1.5 rockers. As does the standard cover.
(Though I realise that information is of zero benefit for you :D )
PostPosted: Wed Mar 30, 2016 5:13 pm
I have Titan 1.5s in my speedway Mini and that has a standard tappet cover.
"Let us remove your "SHORTS"
Users browsing this forum: Barkfast, Bing [Bot] and 95 guests
