It is currently Tue Jul 29, 2025 11:38 pm
PostPosted: Tue Mar 29, 2016 10:11 pm
Hi all,
I just ordered this boss kit from minisport.com
http://www.minisport.com/mllb25h-moto-l ... -1976.html
But it doesn't seem to fit my 1967 Mini Cooper S despite the guy at minisport assuring me it should.
Does anyone know if the australian Minis differ at all?
Any suggestions?
Thanks
PostPosted: Tue Mar 29, 2016 11:20 pm
Hi. It's the B25 boss you will need to fit a Mota-Lita wheel onto an Oz column. The B25's have variants e.g B25A but I'm not sure what the letters mean.
I just had a look at the part number on your link - B25H. Is this stamped on the boss?
PostPosted: Wed Mar 30, 2016 12:34 am
I thought the correct boss kit was the B1H? I've got a mota-lita fitted to my 67 S but I'll need to check which one is fitted.
Rod
PostPosted: Wed Mar 30, 2016 7:47 am
what boss kit do you use on the mini leyland as I was told a different kit again ?
PostPosted: Wed Mar 30, 2016 8:10 am
The one I have has B25 stamped on it.
Doesn't seem to slide on. I'm sure I'm not supposed to force it.
Any chance that the column has been switched?
PostPosted: Wed Mar 30, 2016 9:26 am
All Minis sold here have the same column splines.
PostPosted: Wed Mar 30, 2016 9:56 am
There is a different boss kit for the centre horn and the horn on the stalk, there is also a difference depending on where the indicator cancelling pin is.
I bought a Mountney brand one from the UK for a pre 76 mini and it fit my car fine.
PostPosted: Wed Mar 30, 2016 10:20 am
all minis are 3/4 x 48 splines......I thought
....you just lost him his insurance bonus!
997
PostPosted: Wed Mar 30, 2016 11:05 am
There is also a different boss to suit the MK1 (850) column shroud and the Mini K, Clubman type shroud. If you want it to look right it is important to get the correct one.
PostPosted: Wed Mar 30, 2016 11:36 am
MY horn is on the stalk (indicator lever) but the boss I bought is for a center horn. Could this be the difference.
ie will the boss with a horn kit, still fit a car with a stalk horn?
PostPosted: Wed Mar 30, 2016 11:38 am
This one?
http://www.minisport.com/mllb1-moto-lit ... p-mk1.html
PostPosted: Wed Mar 30, 2016 2:37 pm
eecee wrote:
This one?
https://d31wxntiwn0x96.cloudfront.net/p ... jpeg?etag="30e168dba701fe6a02493c44ee9c4553"?width=400&height=400
That one suits this type.
PostPosted: Wed Mar 30, 2016 10:03 pm
sitnlo62 wrote:
eecee wrote:
This one?
This is what is on my car at the moment.
