It is currently Tue Jul 29, 2025 11:31 pm
PostPosted: Tue Mar 29, 2016 8:55 pm
Hi all,
Pardon my ignorance....
Have my Mk2 S engine out and wanted to change the diff oil seals.....I can't seem to find clear instructions as it seems to depend on the type of joints......apparently quite easy but don't want to stuff it up......
Any help would be greatly appreciated....
Cooper S Mk2
Cooper S Mk1
PostPosted: Tue Mar 29, 2016 9:20 pm
it is as easy as it seems - assuming you have the 4 bolts removed to expose the big bolt underneath, undo said big bolt, remove inner yoke, remove seal, reassemble
PostPosted: Tue Mar 29, 2016 9:26 pm
Thanks,
Looks like a job for tomorrow after work......
Cooper S Mk2
Cooper S Mk1
PostPosted: Wed Mar 30, 2016 10:25 am
I would probably change the side plate gaskets, tappet cover gaskets, speedo drive gasket and seal, and maybe even the timing cover seal.
....you just lost him his insurance bonus!
997
PostPosted: Wed Mar 30, 2016 2:40 pm
Don't forget to replace the seal rubber under the big flat washer. Or oil will find its way out.
I find the ones supplied now are too thick and chew up when tightened, so I slice them with a razor blade to make em 5mm thick. Then I smear them with Loctite 515 and torque the bolt to 72 ft/lb.
PostPosted: Wed Mar 30, 2016 5:41 pm
Thanks all,
Will do all these as suggested while engine out, as well as respray touchup.....
Easier when out than in...... :D
Cooper S Mk2
Cooper S Mk1
Users browsing this forum: Barkfast, Bing [Bot] and 100 guests
