It is currently Tue Jul 29, 2025 11:33 pm
 Post subject: Dash lights
PostPosted: Thu Mar 17, 2016 7:17 pm
Hi all quick question on electrical again. I'm not getting any dash lights besides ignition light replaced globes, but when I fit them into speedo they don't work. I've checked bulb holders with test light and they are working. Any ideas?
 Post subject: Re: Dash lights
PostPosted: Thu Mar 17, 2016 9:16 pm
they earth through the gauges, so make sure there is an earth wire between them and to the body
PostPosted: Fri Mar 18, 2016 6:55 am
Are they LED globes? They need to be installed the correct way. One way will work and 180 degrees the other way won't.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Fri Mar 18, 2016 5:55 pm
Just original globes
PostPosted: Fri Mar 18, 2016 7:23 pm
If it is a leyland check the dash light Dimmer. It might be open circuit or crook. You can bypass it by putting both wires on the same terminal.
"Let us remove your "SHORTS"
PostPosted: Sat Mar 19, 2016 5:13 am
It's a roundy
PostPosted: Sat Mar 19, 2016 7:49 am
Some round nose Minis had a small toggle switch for the dash lights on the side of the Binnacle.
PostPosted: Mon Mar 21, 2016 7:36 pm
No toggle switch. Still can not work it out. Only work when test light is stuck down the holder. Oil pressure light should only come on when it looses pressure? How do I test the earth? Single wire globes still don't work when put into speedo
PostPosted: Mon Mar 21, 2016 8:33 pm
when you think the lights should be on, get a piece of wire and hold a bare end against the back of the gauge and against something that's bare metal... if you have a piece of wire long enough, hold it against the earth strap on the motor (below the clutch housing)
PostPosted: Tue Mar 22, 2016 8:18 pm
Got them working now just can't get the wiper motor to work
PostPosted: Tue Mar 22, 2016 9:03 pm
Bwahahahaha Lucas the Dark Prince strikes again... :lol: :lol: :lol: :lol:
Maelgwn No Mini Yet :(
PostPosted: Tue Mar 22, 2016 9:24 pm
what was the culprit?
is it earthed properly? the body isn't earthed through the mounts, and none of the wires that go to it are earths. It needs its own earth wire to the body. There is a captive nut on the radiator side triangular brace that is there specifically for that purpose
PostPosted: Wed Mar 23, 2016 12:26 pm
Ohk do you have a wiring diagram for it? Maybe I have the wires wrong on the switch
PostPosted: Wed Mar 23, 2016 2:19 pm
this is my favourite manual, has wiring diagrams
http://www.ebay.com.au/itm/MINI-1959-19 ... SwDNdV47Pt
PostPosted: Thu Mar 24, 2016 8:49 pm
What wires go where on the switch, I have one red one black and one black and green stripe. I'm not getting power to any of them
Users browsing this forum: Barkfast, Bing [Bot] and 112 guests
