It is currently Tue Jul 29, 2025 11:34 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 Post subject: hose clamps
PostPosted: Wed Mar 16, 2016 1:25 pm
Hi Guys needing help with the correct radiator hose clamps for mid 69 Cooper S. When did the wire type clamps finish? Where might i be able to buy the correct clamps?
 Post subject: Re: hose clamps
PostPosted: Wed Mar 16, 2016 2:03 pm
Utilux No H510 and 1 1/4" diameter. They are very hard to find. The change over was 67/68 from the wire clamps.
Aftermarket ones are made for the Ford and Holden guys but they are either too big or small and have a thicker section of metal between the straps. https://www.rarespares.net.au/rarespare ... uct=CS1003
Edit- H510 in the catalogue above are different to the ones used on our cars. The correct clamps have raised edges to retain the nut instead of a single tab
PostPosted: Thu Mar 17, 2016 3:50 pm
Found these on eBay...
http://m.ebay.com/itm/152007150299
PostPosted: Thu Mar 17, 2016 4:38 pm
Similar but not the correct type.
Davem's look original
PostPosted: Thu Mar 17, 2016 5:09 pm
Yep the radiator hoses are, but the fuel line clamps have to be wrong, what should a mk2 have for fuel line to carbs?
1993 R32 Nissan Skyline GTR
PostPosted: Thu Mar 17, 2016 5:13 pm
davem wrote:
... what should a mk2 have for fuel line to carbs?
These - http://minikingdomonline.com.au/product ... rburettor/
PostPosted: Thu Mar 17, 2016 5:31 pm
Thanks and the braided lines to the carby are correct?
PostPosted: Thu Mar 17, 2016 6:02 pm
Yes. Here's my engine bay as it was after more than 20 years in hibernation. You can see the braided lines and clip on the right. The fuel line and clip on the left was done later.
PostPosted: Thu Mar 17, 2016 6:15 pm
Might be correct but rusty, what would you prefer? Just saying. Richard.
PostPosted: Thu Mar 17, 2016 7:27 pm
I have NOS green clips from MKO to replace the rusty ones, if that's what you are saying. :?
PostPosted: Thu Mar 17, 2016 7:31 pm
I don't need them so sell them to kath20
PostPosted: Thu Mar 17, 2016 7:35 pm
The wire fuel line clips work a treat actually. I've had them fitted for the last seven years without issue. They're kinder to the braided lines as well as they don't spread and split the rubber boots.
PostPosted: Thu Mar 17, 2016 9:52 pm
Is there a special tool for putting these on spring clamp things on?
I find them REALLY hard to work with just using pliers, They slip out and it just isnt fun.
PostPosted: Thu Mar 17, 2016 10:47 pm
Fencing pliers??? They have a groove in each jaw to hold the wire clips..
Cheers, Ian
PostPosted: Fri Mar 18, 2016 2:46 am
Changeover was way earlier than that. I believe early 66 is the earliest car I have had with them on it that i believe were original. Was only a deluxe but they were there. So could have even been prior to this.
1962 Mini Speed sports sedan
Users browsing this forum: Barkfast, Bing [Bot] and 100 guests
