It is currently Wed Jul 30, 2025 9:14 am
 Post subject: Two screw rear lamps.
PostPosted: Wed Mar 16, 2016 3:48 pm
Hi guys n gal's, simple question here, I'm just changing some globes in the rear tail lights. The lense just flops about. Is there supposed to be a seal between the plastic lense and the body of the light assembly? Cheers.
PostPosted: Wed Mar 16, 2016 3:52 pm
Yes, there should be one on each side of the chrome base
http://minisport.com.au/mini-2-or-3-scr ... orris-type
PostPosted: Wed Mar 16, 2016 3:54 pm
Yes there is a foam gasket behind the lens.
54570450 is p/no in my Mini K book. For 2 screw lens.
PostPosted: Wed Mar 16, 2016 4:10 pm
Ok thanks fella's :)
PostPosted: Wed Mar 16, 2016 4:57 pm
Piece of high density closed cell foam from someone like Clark Rubber... Or the underlay they use under wooden floating floors is pretty close in thickness and even colour. Only takes a few minutes to trim to size.
Cheers, Ian
PostPosted: Wed Mar 16, 2016 5:36 pm
Ian, you beat me to it. I did the same. :) it outlasts the bought gaskets too
Users browsing this forum: Bing [Bot] and 85 guests
