if it`s running hot then you obviously have an issue to sort
most minis (even 1500cc & 1600cc ones) don`t need any extra heater core or fandangled thing to help cool it
i`d expect you have issues with maybe thermostat stuck shut, or cracked head or blown/weeping head gasket, or too retarded ignition,,, or too lean mixture,,, or blocked radiator,,,, or water pump impeller corroded or not good enough,,, etc etc etc,,, Or any combination of all of the above
plenty of things can make them run hot,,, best to sort them all before attempting to "Cover up the symptoms" instead of "Curing the cause"
that`s what i say anyways,,, if it`s running hot then you have to sort the reason why it`s running hot instead of trying to cover it up with a band-aid
simple as that !!!!!!!!!!
_________________ No offence intended here but--> anyone writing a book about minis 30 years ago may not have experienced such worn or stuffed-with components as we are finding these days.
