It is currently Wed Jul 30, 2025 9:21 am
 Post subject: Pistons
PostPosted: Sun Mar 06, 2016 4:16 pm
Are these any good?
http://www.ebay.com.au/itm/MG-MIDGET-SP ... SwaNBUe8dy
 Post subject: Re: Pistons
PostPosted: Sun Mar 06, 2016 7:39 pm
Mahle are a good brand.
I would check the compression ratio is what you are after, as they look to have a large dish and may be low compression.
Are they +40 as per the piston or +60 as per the title - or they may have both.
PostPosted: Mon Mar 07, 2016 10:38 pm
They are +.040 and low compression. IN THE PICTURE! Best to ask and make sure it is not trick advertising.
"Let us remove your "SHORTS"
