It is currently Wed Jul 30, 2025 7:21 am
 Post subject: 1978 mini
PostPosted: Sat Mar 05, 2016 3:07 pm
Just replaced cones and knuckle and the swing arm will not move up enough to fit the new shock absorber. I am wondering if this is normal or are the trumpets too long. are there different lengths? TIA
1978 Leyland Mini 1275 LS
Hi Ho Silver and hopefully away
 Post subject: Re: 1978 mini
PostPosted: Sat Mar 05, 2016 3:14 pm
Are the knuckle and cone properly seated all the way in? Did you remove all of the old knuckle joint nylon cup?
PostPosted: Sat Mar 05, 2016 4:53 pm
Some new cones sit higher than the old ones. Check what Timmy said first. You may need hilos. First I would put a jack under the arm and see if you can get it into the shocker then. See how high it rides, hilos are a good upgrade regardless.
PostPosted: Sun Mar 06, 2016 11:24 am
Thanks for the reply. Knuckles are seated fully with 3mm clearance to the lip. cone seated properly, put a jack under arm but only goes so far then lifts body shell. I will let it sit and see if they settle. Graeme
PostPosted: Wed Mar 09, 2016 6:59 pm
Hi Graeme,
We put new cones in and even with hi lo's it's still sitting high, not wound all the way down (or up from hi lo perspective) but pretty close. Hasn't been out for a run yet though so its as installed.
PS. How's yours going. Getting close ?
PPS. Make sure you upgrade the steering rack if required before installing motor and all associated bits. I had to do the GT, what a job !
Geoff.
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Thu Mar 10, 2016 1:55 am
Maybe the use of the cone tool to compress the cone is needed to help put every thing back in
http://www.classicmotoring.net.au/cmos/ ... 279241c558
http://www.reizendemoke.be/techniek/man ... necomp.gif
PostPosted: Thu Mar 10, 2016 6:05 pm
I think he's talking about the rear swing arm. Shouldn't need a compressor there. Hilos!!
PostPosted: Sat Mar 12, 2016 5:09 pm
Thanks all I have got them in. Had to undo swing arm and get the strut in then refit the swing arm. It does sit high but should settle a bit when it gets a bit of weight on it. I intend putting a new steering arm in and save any drama thanks 1978 clubbie. Starting to do the rebuild of front end now then motor then interior
Graeme
PostPosted: Sat Mar 12, 2016 5:12 pm
Graeme
Good to know you eventually got it to fit. Keep us posted on how you go with the front :)
