It is currently Wed Jul 30, 2025 10:27 pm
 Post subject: Pott Joint info please
PostPosted: Sun Feb 28, 2016 5:35 pm
can anyone tell me if the size of the balls in clubman inner pot joints changed sizes in later models or is there a diference when going from imp sizes to metric. the replacement balls that i got have caused me drama
Graham
PostPosted: Mon Feb 29, 2016 9:48 am
21/32 is the size they are all supposed to be, i`ve not found any other sizes so far, but the race`s & cages differ in sizes for the reco ones, i`ve found 4x different sizes of those so far
beware :-)
PostPosted: Mon Feb 29, 2016 12:36 pm
beware :-)
Matt, where do you stand on fitting bigger balls in worn pot joints to make em niceandtite? :D
PostPosted: Mon Feb 29, 2016 5:14 pm
sorted the problem the supplier got the balls mixed with metric and they ended up being 7th bigger than needed. they fitted my pot joint and went in with a slight bit of force but would not allow full movement without jamming. was lucky as on test run the shaft pulled out of cvjoint and started doing loops. ended up with a new pot joint today so all matches. one problem I got is that the hole in the sub frame is not big enough to allow inner pot joint to pass through so have to fit after shaft put through without joint on thanks for the help
graham
another thing are minis getting lower or am I just getting old
