It is currently Thu Jul 31, 2025 7:48 pm
PostPosted: Mon Feb 01, 2016 9:26 pm
This may help some people.
It's an original nos stock tool kit and bag I have with my Mk1 1967 Cooper S
There is also a picture on page 23 of John Parnell's book 'Original Mini Cooper and Cooper S'
John
johnl
PostPosted: Mon Feb 01, 2016 10:00 pm
Wow, that's incredible, thanks for sharing.
Mini's I grew up with
Slot car couch
PostPosted: Wed Feb 03, 2016 11:30 am
Thanks for posting. Very nice and another item to start hunting for!
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Wed Feb 03, 2016 1:09 pm
It might be NOS tool kit but is it the tool kit as fitted to Australian Minis? I have never seen a red jack in an Aussie Mini.
PostPosted: Wed Feb 03, 2016 1:47 pm
My rover mini tool kit had a red jack handle and gloss black jack.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Wed Feb 03, 2016 3:40 pm
Our '62 850 has a red jack and handle, but given it's CKD you could argue it's not Australian :)
That NOS one is incredible!
Evan
PostPosted: Wed Feb 03, 2016 4:10 pm
One possible problem is what was sold by Parts and Accessories and what was fitted on the production line may be two different things.
The took bag doesn't look like the tool bags in any Minis I have owned.
PostPosted: Wed Feb 03, 2016 4:28 pm
I've had a look through various Australian Mini parts books and engineering drawings. The following is what is documented by BMC, so not necessarily what occurred in practice, although I've no reason to think differently. Only the Mini saloon jack is discussed here. Mini van jacks are of a different design.
The jack specified for the Mini saloon from November 1965 through to final Mini production in Australia (end 1978) is part AYA2156 (example pictured below from my MK II S). The engineering drawing shows it to be 18.44 inches high from the base to the top of the screw nut. The finish is black lacquer. It has an instruction decal with white writing and diagram on black background affixed to the flat of the upright. The jack was made for BMC Australia by APAC Industries (Finsbury, S.A.), later to become Clyde-APAC.
The previous version of this jack, part AYA2054, is shorter at 15.25 inches high and was released into production in March 1964. Prior to this date I believe UK manufactured jacks of the same basic design were used but I'll do a bit more investigation on this.
Apart from being 3 inches shorter, the earlier jack (AYA2054) is missing the short piece of 1/2" bar welded to the lifting lug (see drawing below). I assume this design change was to limit the travel of the lifting lug, for safety or metal fatigue and stress reasons. Also, in September 1964 the background to the instruction decal was changed from transparent to black. No idea why, although I've heard transparent sticky labels are difficult to print on, so maybe the instructions were being rubbed off over time.
I believe the jack handle with hub cap removal tool on the end was always red in Australia.
PostPosted: Wed Feb 03, 2016 4:37 pm
APAC jacks, including the Mini one are mentioned here - http://www.ozwrenches.com/jacks.htm
PostPosted: Wed Feb 03, 2016 6:52 pm
I have a black jack handle in my 69 cooper s
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 03, 2016 7:13 pm
Red one out of a very original Cooper, seems to be a different design as well as just being red compared to black.
Different end cap design as well as the round bar not being present.
Slot car couch
PostPosted: Wed Feb 03, 2016 7:20 pm
Does it have the chisel end for removing hub caps or a blunt end? If the latter then a separate hub cap tool was probably included in the tool set.
PostPosted: Wed Feb 03, 2016 8:55 pm
It has a chisel end to remove hub caps
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Feb 04, 2016 1:43 pm
That is the same as what came in my `61 850. All early 60s jacks were red.
PostPosted: Fri Feb 05, 2016 6:13 pm
John
Hi
Just to add my thoughts to this one.
The jack bag has a different surface look to what I think is original. It could be just the light but looks different.
The tie straps are flat plastic on what I think is original.
I got two jack bags with the Cooper S ( 1970 ) One used also. They are both the same.
I have a mint nos bag which I've had for a number of year's. Never used.
My Cooper S came some what complete and original with a black jack and red handle and a hub cap remover plus original owner's hand book.
Not to say I'm right but that's my experience with this subject.
Users browsing this forum: cruiser23 and 82 guests
