It is currently Thu Jul 31, 2025 7:43 pm
PostPosted: Sun Jan 31, 2016 1:55 pm
Hi all,
In case anyone does not know I am converting a minimatic to manual rod change meaning of course making holes in the floor. I would imagine the easiest way to do this is with the gearbox in situ but I would rather not leave it til then as I would like it to be painted after this.
I guess to do this I need a template showing the cutout/holes which is accurate. Has anyone had success doing it this way, or do the holes need to be 'spot on' and I should wait til after the gearbox is fitted?
Thanks
Jon
PostPosted: Sun Jan 31, 2016 6:17 pm
Hi Jon,
The clubman floor pan from which the typical rod change gear box comes from has a larger tunnel with another pressed section for the bracket mounting for the gear change and mount compared to Aussie Morris Mini's. I suspect this will also apply to the Minimatic.
Thus you will need to do some work on the bracket to make the gear change fit, and I think the gearchange will sit a little lower (a little less ground clearance).
When I have fitted rod change gearbox's to Aussie Morris minis I have also cut and shut the floor and fitted the clubman tunnel in. Bit of work but then I use all standard parts once the floor is done.
PostPosted: Sun Jan 31, 2016 6:29 pm
When we owned Barney the pretend S with a 67 deluxe shell, the PO had fitted a 1098 & rodchange to it. It worked fine but we swapped a 1293A+ and Mini K box in coz I dislike a rodchange's lack of location against torque. But the rodchange cleared the floor OK.
PostPosted: Sun Jan 31, 2016 7:39 pm
Hi, well the floor is rusty and it may be worthwhile to replacing this with the leyland version. I will think about this one.....
Thanks
PostPosted: Sun Jan 31, 2016 7:59 pm
So I have a 850 shell would a rod change fit in this if I make a bracket for the back have been told it will hit the floor or put the rod change at a funny angle and cause a oil leak
PostPosted: Sun Jan 31, 2016 9:32 pm
Nah, if it gives an oil leak it needed a new seal. Plenty of early floor cars running with a rodchange box these days.
