It is currently Fri Aug 01, 2025 4:06 pm
PostPosted: Mon Jan 25, 2016 7:44 pm
Hi guys,
Can someone identify this spring?
It comes out when I change the Oil.
Car has been running usual other than popping out 2 gear on deceleration.
Which I suspect just a bad 2nd gear.
I just drain my oil and this spring sticking out of the drain...
Surely it's not meant to be in there..
It's about 30mm long
18mm dia
Thanks!
PostPosted: Mon Jan 25, 2016 9:37 pm
Looks like a detent spring, used in all non-rodchange boxes. There are 4 of em. 1-2, 3-4, reverse, and reverse gate.
No idea how it could get inside the box, 3 are external fitment except reverse, which is trapped in a blind hole.
BTW, diameter is ~8mm not 18.
PostPosted: Tue Jan 26, 2016 9:29 pm
I see thanks for the info.
Yes it's 8mm
Sorry for the typo, was posting with oily hands while servicing ;)
that's correct mine is the older non rod shifter boxes.
where can I find where this spring located on the external of the box?
PostPosted: Tue Jan 26, 2016 9:41 pm
There are 2 hex plugs near bottom, on the clutch side. They are 1-2 and 3-4 detents.
The reverse gate lockout one is under a big hex plug (or reverse switch) behind the oil filter.
The reverse detent one is inside the casing, cannot be removed until the 1-2? selector shaft and its detent plunger & spring are removed. Then the reverse selector shaft is removed, followed by the reverse detent plunger & spring.
PostPosted: Wed Jan 27, 2016 8:25 am
Are you using a standard sump plug. Some of the extended ones had a long spring to hold the magnet on.
PostPosted: Wed Jan 27, 2016 9:20 pm
<mod edit on the title>
Sorry but seeing "doing" coming out with the oil was bugging me.
michael
PostPosted: Wed Jan 27, 2016 9:47 pm
michael
What's the problem? "Doing" is the sound a spring makes as it shoots across the workshop.
PostPosted: Thu Jan 28, 2016 9:14 am
And also what your phone might think you are typing if you have a "smartphone"
PostPosted: Thu Jan 28, 2016 10:44 am
michael
That's the sound of it reaching escape velocity, never to be seen again...!
