It is currently Fri Aug 01, 2025 4:08 pm
PostPosted: Tue Jan 26, 2016 8:35 am
So what are the differences between a MK1 and MK2 Cooper S Engine Block besides the engine numbers :shock:
1970 MK2 Cooper S
PostPosted: Tue Jan 26, 2016 9:40 am
Mk 1 has a thin flange and M2 the thick flange (where the block meets the gearbox).
PostPosted: Tue Jan 26, 2016 10:07 am
And very early Mk1s reputedly were weaker around the centre main.
PostPosted: Tue Jan 26, 2016 10:36 am
Do you know roughly up to what engine numbers? eg 9FSAY 38000
PostPosted: Tue Jan 26, 2016 10:58 am
Some early Mk2 Cooper S's (my Mk2 is car number 336 and it has the thin flange block) also had the thin flange block but with the 9F/XE/Y engine number and reportedly some late Mk1's had thick flange blocks.
Probably fair to say that sometime in mid 69 there was a transition from thin flange to thick flange blocks - nominally around the introduction of the Mk2. :?
PostPosted: Tue Jan 26, 2016 11:17 am
yes this is true Rodmac.
PostPosted: Tue Jan 26, 2016 7:56 pm
Keep in mind that the /SA/ refers to the gearbox type, 3 syncro and /XE/ refers to gearbox type 4 syncro.
I have also seen a lot of XE thin flange blocks but cant recall seeing a SA thick flange block. Not that it didn't happen, possible I guess.
PostPosted: Wed Jan 27, 2016 9:32 am
The thick flange MK2 block I have has a stiffening rib adjacent to the dip stick hole.
The question is:
Do all thick flange S blocks have the stiffening rib?
RonR
68 build Mk1 Cooper S
Users browsing this forum: Bing [Bot] and 102 guests
