It is currently Fri Aug 01, 2025 4:06 pm
PostPosted: Fri Jan 22, 2016 5:54 pm
Bloody hot driving a mini in the summer specially in stand still traffic. Was thinking about buying 1 of those 12v fans but just seeing what others have done? Is there anything better? Or is an aftermarket air con unit worth it?
PostPosted: Fri Jan 22, 2016 7:14 pm
I have a Rover with the extra thermo fan and even the other day at over 40 it still didn't get hot enough for fan to cut in. I have the standard plastic fan on engine.
If you want one grab a 10" davis craig one and fit it on outside of radiator, under guard. Just wire it up using ignition power to earth to switch relay, then if you forget to switch it of it will with key.
PostPosted: Fri Jan 22, 2016 7:23 pm
I actually meant for inside the cabin
PostPosted: Fri Jan 22, 2016 7:38 pm
I had one back in the 60s, they are better than nothing. I still have an old one on the shelf. :)
PostPosted: Fri Jan 22, 2016 7:49 pm
Tried Harvey Norman?
"Let us remove your "SHORTS"
PostPosted: Fri Jan 22, 2016 7:54 pm
Sounds like the easy solution doc lol
PostPosted: Fri Jan 22, 2016 7:57 pm
Ha ha, oh well, mount the Davis Craig fan on the dash. ;-)
PostPosted: Sat Jan 23, 2016 11:54 am
I don't think they do anything other than blow hot air around inside. Unfortunately the side quarter front widows don't do much either when you're standing in traffic, although they work ok when on the move. Aircon is the answer but it never looks right in a Mini engine bay, is a pain if you have to any work in there, and adds weight.
Having said that, I drove Minis for almost 4 decades without any aircon fitted (very few cars had aircon in the 60s, 70s) throughout some of the hottest summers and survived, vinyl seats and all. Maybe we need to man up a bit more these days.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sat Jan 23, 2016 1:37 pm
Haha yea that's true.
PostPosted: Sat Jan 23, 2016 9:03 pm
My car had one with it when I got it. I don't have it in the car most of the time, but if you are spending much time idling or in traffic it's a huge help. Once you are moving above 60kph you don't notice it if you have the windows open.
PostPosted: Sat Jan 23, 2016 9:23 pm
The little hardware shop down queen st st Marys sell the white one with the blues fans like all kombis used to have in the 70s-80s
I still may have my one some where as well
