It is currently Sat Aug 02, 2025 7:20 am
 Post subject: Starter motor
PostPosted: Wed Jan 13, 2016 11:47 am
Does anyone know what might have caused this to happen ?
I have just rebuilt the carbs and was trying to get it to run, had to turn it over for a fair while
 Post subject: Re: Starter motor
PostPosted: Wed Jan 13, 2016 12:14 pm
They are pretty weak there. Either fit a new pinion assembly or another starter
PostPosted: Wed Jan 13, 2016 12:21 pm
Be careful getting the circlip off. It's tricky but can be done using a vice, vicegrips and a small blade screwdriver. Use safety glasses!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Jan 13, 2016 1:00 pm
I'd fit an exchange recond starter. Or a Holden Gemini one is better.
PostPosted: Wed Jan 13, 2016 4:27 pm
Ha ha. PING!
PostPosted: Wed Jan 13, 2016 4:31 pm
I have a few old starters if you need that part just message me, postage only.
PostPosted: Wed Jan 13, 2016 8:23 pm
To answer your question, did the engine back fire when you were starting it. If you did the starter was to slow to return back. As damage looks like impact damage from the flywheel.
Also check if the shaft is bent
PostPosted: Wed Jan 13, 2016 9:54 pm
I broke a few of these when I needed to run 20deg static timing in this bathtub headed motor with a Pulsar dizzy. It fired on the first compression stroke and BANG! another pinion broken. No problem since I've fitted the stealth black box.
PostPosted: Thu Jan 14, 2016 10:15 am
Unsure if the engine did back fire, as I said had to turn it over for a while before it sort do fired
PostPosted: Wed Jan 20, 2016 3:30 pm
This got me motivated and I pulled out some old starter motors, is there a trick to getting the gear and spring assembly off or do you need a special tool to compress it?
PostPosted: Wed Jan 20, 2016 3:37 pm
I have starter pinion compressing tools for sale $35.00
"Let us remove your "SHORTS"
PostPosted: Wed Jan 20, 2016 3:39 pm
You need a safe way to compress it.
I use the tailstock on my lathe, with a bit of tube that has a slot cut in it. you could also use this in a bench drill.
Or a press would be nice...
PostPosted: Wed Jan 20, 2016 3:44 pm
Is there a collet that needs to be removed once compressed?
PostPosted: Wed Jan 20, 2016 4:05 pm
A wire circlip.
PostPosted: Wed Jan 20, 2016 4:46 pm
Early Lucas starters to ~1960 had 2 locknuts instead. Better idea...!
