It is currently Sat Aug 02, 2025 8:36 am
PostPosted: Mon Jan 11, 2016 6:15 pm
I'm having problems with my 1500 ohc motor and Speedo not agreeing with each other. So, my question is, if my Speedo is reading a lot faster than I'm actually going and I wanted to replace the Speedo gear with a more appropriate one, where do I start looking?
Will a gear that typically fixes this problem in a mini fix the problem with my 1500 motor too?
PostPosted: Mon Jan 11, 2016 7:14 pm
Don't know anything about 1500...
... But a good site for mini speedo gear info :
http://www.guess-works.com/Tech/speedo.htm
PostPosted: Mon Jan 11, 2016 8:09 pm
I don't think the speedo gear is related to a Mini, the part numbers from the Australian Morris 1500 parts books don't seem to get any hits on google.
The parts book lists 42H67
The price book lists 24H67A being replaced by 42H1294.
The best thing to do is work out how far out the speedo is running and get the speedo recalibrated to match the car.
PostPosted: Mon Jan 11, 2016 9:55 pm
The speedo runs on a magnetic drive and easilly recalibrated.. The odo is gear driven however.
Cheers, Ian
PostPosted: Tue Jan 12, 2016 6:45 am
Speedo repair shops can supply a gearbox that screws onto the cable for calibration.
